Author Topic: Close to THE ROCK, 1970 R/T S/E Challenger, 8/13 update  (Read 84390 times)
Offline DAYLEY/CHALLENGER
Re: Close to THE ROCK, 1970 R/T S/E Challenger, 1/03/09
« Reply #315 on: August 15, 2009 - 10:40:23 PM »
My son is changing my web site.  He has some of the chapters started  but in a new format.  It will take a few weeks to finish but at least this will be on line and show more pics of the resto. I know some of these pics in this thread has dissappeared but the website will show a lot more anyway.
I have been to a few more cruise-ins and some pics attached...
« Last Edit: August 16, 2009 - 06:03:48 PM by DAYLEY/CHALLENGER »
Dave or David
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: Close to THE ROCK, 1970 R/T S/E Challenger, 8/15/09
« Reply #316 on: August 15, 2009 - 11:25:16 PM »
looks very   :thumbsup: :2thumbs:
72rtchallenger
what happens in the garage
stays in the garage
« Reply #317 on: November 08, 2009 - 08:40:38 PM »
Well uploader is full as usual...........SO.........More pics of my Challenger on Photo Bucket.........I will be adding more during the winter of some of the work done over the past 5 years........No particular order, just some interesting pics.........
http://s669.photobucket.com/albums/vv53/DAYLEY-CHALLENGR/My%201970%20Challenger%20pics/?albumview=grid
And my son is in the active mode on restoring my website now........... :bigsmile:
Dave or David
Re: Close to THE ROCK, 1970 R/T S/E Challenger, 11-09
« Reply #318 on: November 08, 2009 - 10:32:28 PM »
Calendar Worthy ......
« Reply #319 on: November 09, 2009 - 07:14:52 AM »
Thanks Wade.   Not as good as it could have been.  I could have a better shot but that is a one way street.  The sun was on the left so could only get the rear view bright.  The trees are in a church yard........best I didn't get on the grass.......and I was afraid to wait another week for the leaves to change some  more.  Last year i was going to do the same pic........tree was full on a Friday afternoon and I went back Sat morning and after a rain Friday night the tree was bare.   Later, David
Dave or David
Offline mcgheejt
« Reply #320 on: November 09, 2009 - 11:18:24 AM »
« Reply #321 on: November 26, 2009 - 08:57:05 PM »
I've got a 19 month old Mopar driver..............His dad said it was a good thing he couldn't reach the gas. :burnout: :burnout:
Dave or David
« Reply #322 on: November 27, 2009 - 03:57:53 PM »
Got my pinion seal replaced today...........thought I would post here too..........http://s669.photobucket.com/albums/vv53/DAYLEY-CHALLENGR/Pinion%20seal%20Change/Pinion%20seal%20change/
Dave or David
« Reply #323 on: December 26, 2009 - 01:03:28 PM »
OK........I got the hood blackout for Christmas.........Any  specific tips for installing??????????????
Dave or David
Offline ChallengerGary
    • Challenger Gary
Re: Close to THE ROCK, 1970 R/T S/E Challenger, 12-26-09
« Reply #324 on: December 26, 2009 - 07:09:48 PM »
Be very careful.  If there was a spary gel incuded use it.  If not use a solution os water, dish soap (several drops) and a capful of rubbing alcohol.  Squeegee the death out of it.  When you think you are done sqeegeeing - do it some more.  Best bet is to install it when the temperature is over 60 degrees F.  If you remove the transfer tape and there are some bubbles - do not stres about it - that is very common and will usually come out with time.
Lastly, this is actually one of the most difficult decals to install, if you doubt your ability to do it, try contacting a local sign company and see if the have someone that cna do it for you.
Good luck  :2thumbs:
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline usraptr
« Reply #325 on: December 26, 2009 - 10:12:37 PM »
Dave, just reviewed your web site of your restoration.  Great job!!  :2thumbs:  Question: I noted that your "zeroed" out your speedo during your build.  Did you do this yourself?  If so, do you have any tricks other than the drill hooked up to the back of the speedo?  Thanks
(Edited 8-1-17)
« Reply #326 on: December 27, 2009 - 07:21:27 AM »
From my very limited experience you want to measure & mark the center of the hood and the decal, tape the decal down at the center, there should be a seam in the backing paper about there. Remove the paper from the center pulling from underneath spraying Gary's spray solution as you go, then remove tape & do the other side...on a piece this large you could use an exrta set of hands IMO.
Rot's-O-Ruck  ;D
Wade
« Reply #327 on: December 27, 2009 - 08:50:18 AM »
Hey Brad........Thanks for the comments........If I remember correctly.....I actually somehow took the drive gear loose and manually reset all the numbers to 0.  No drill was used.........It wasn't hard to do but I didn't take pics of the actual process and now I wish I had......Good Luck.
Wade...........Come on up............... when it gets to 60 degrees up here I can install..........I have requested directions from the supplier....Waiting on them too.  :bigsmile:
Dave or David
« Reply #328 on: December 28, 2009 - 10:52:57 PM »
I looked at several clips on applying vinyl...........this one I think should work for the hood blackout..........
http://www.ehow.com/video_2331894_applying-vehicle-graphics-wet-center.html?cp=1&pid=1
If not.........please tell me now..............
Oh.......should I do the front narrow part first and then the wide or do one side and then the other.............????
« Last Edit: December 28, 2009 - 10:55:50 PM by DAYLEY/CHALLENGER »
Dave or David
« Reply #329 on: December 29, 2009 - 05:28:43 AM »
Pretty much how I would approach it but I'd hope there would be a seam in the backing paper that you could pull  from the middle out doing a little at a time rather than a whole side at once... if the seam is there I'd use whatever that indicates otherwise do one side & then the other like in the video.  :2cents:
See in these pics how the backing is curled back from underneath
