Author Topic: Race Dana 60 with Wilwood Brakes  (Read 941 times)
Offline zokster
« on: September 11, 2006 - 08:35:35 PM »
 Rear end will fit an A body with big tire (16x33) with about 3/4 " clearance on each side. Spool, 4.56 gear ratio, Moser 35 spline axles, axles are 5 on 4-3/4" bolt circle. 5/8" studs with spacers and lug nuts. Rear end is 41" out side to outside of brake rotors (total width) Has 4-link brackets which are on 20-3/4" centers. Also has wheelie bar tabs, anti-roll tabs, and adjustable shock mounts. Wilwood brakes are included with rear end and are mounted on rear end. Rear end has approximately 80 1/8 mile passes in about a 2200lb car. $1,500.00 firm for rear end with Wilwood disc brakes. Will not seperate brakes from rear end. Contact: Michael Steele @ HEADS UP CHASSIS. 850-675-0176 for pics, e-mail me at  zokster1@aol.com                   Thank You
