Author Topic: HELP! 4-SPEED QUESTION  (Read 1797 times)
Offline REPOMAN
  • Bustin knuckles
« on: July 20, 2003 - 12:06:10 PM »
 After replacing my rubber fuel line from the tank to the hard line I found out the hard way that my tranny was stuck in 1 st gear. I need some advice on what to do to un stick it.
I'd rather be BLOWN than INJECTED!
FOUND: Sell slip on my cuda!
$2,000.00 On Dec. 7 1977
Re:HELP! 4-SPEED QUESTION
« Reply #1 on: July 20, 2003 - 12:56:35 PM »
You probably jammed it in 2 gears or shifted the linkage without using the stick , get underneath & shift all the gears into the neutral / center position
