Author Topic: Aftermarket gauges and placement  (Read 1327 times)
Offline Mike71Cuda
« on: September 13, 2006 - 12:16:17 PM »
I am trying to find a good place for my aftermarket gauges (other than pod below dash). Had my rallyle dash redone so thos egauges are ok, but things like: tranny temp, fuel pres. etc. Trying to find a place that I can retro fit without destroying it. I was thinking about ashtray. Glove box, but they would be tough to see. Sqaw a car with a pod that popped up from center speaker which would be a cool one, but don't know who sells it. Any ideas out there?
Offline GoodysGotaCuda
Re: Aftermarket gauges and placement
« Reply #1 on: September 13, 2006 - 12:32:02 PM »
Someone had that pod out of the speaker opening and it looks pretty cheesy if you ask me. You can turn your factory water temp gauge into a trans temp gauge by installing a switch and sender for the trans. You can switch the gauges sender wire to the motor or trans. It wont be accurate like a autometer, but you get the idea.
What other gauges are you looking to mount? Fuel pressure will have to be outside of the car unless you get a isolator or electrical gauge (which is $$ btw)
 :bigsmile:
« Last Edit: September 13, 2006 - 12:34:55 PM by GoodysGotACUDA »
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #2 on: September 13, 2006 - 02:46:27 PM »
Here's where I put my fuel pressure gauge. This pic makes it look worse than it seems. I have NO idea what that brownish shadow is around the upper left of it. Oh to be a good photographer.  :banghead:
« Reply #3 on: September 13, 2006 - 11:38:38 PM »
you can always adapt a pod to the A pillar
« Reply #4 on: September 14, 2006 - 12:20:45 AM »
i used to have gauges down there too
1976 Dodge Warlock
