I finally got back to finishing the install of the Hemi in my Curious Cuda. Thanks to everyone for there knowledge on the details, I could not have done it without you guys/gurls! So now for the really important questions: What do to for first fire up?
I know to build up oil pressure-I am going to crank over car with no coil wire to get the flow going. Got my Oil pres gauge all starighted out. What else? What is the best way to burn the cam in-someone told me to run car just above 1,000 rpm steady for 15 minutes, turn car off for a 1/2 hour, and repeat? DOes cam lube disapate, after so long? Any way to freshen up? Engine has sat in my garage for over 5 years, I have turned crank periodically to avoid cease up. Engine is a brand new, 0 mile engine (block heads crank from MP, all other stuff is aftermarket). Running engine with 30 weight conventional oil. Will flush it and replace oil once it is broken in. Don't want to come this far and wipe it out right outta the box. All comments welcomed. Thanks again for your help in advance.
Smitty
