Need the mixing ratio for B5 (medium blue) interior color
Author Topic: Need the mixing ratio for B5 (medium blue) interior color  (Read 3463 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: September 15, 2006 - 01:28:09 PM »
Need the mixing ratio for B5 (medium blue) interior color so I can have a local paint shop mix it for me. As I can't buy the paint from the USA, since the costums in the USA will not allow paint to be shipped out of the USA. And I don't know of any dealers in Norway that has the paint/ spray
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline torredcuda
  • Epping NH joined 11/23/03
Re: Need the mixing ratio for B5 (medium blue) interior color
« Reply #1 on: September 16, 2006 - 05:20:04 AM »
Go here for the factory codes-
http://autocolorlibrary.com/cgi-bin/search/searchpic.pl?1970-plymouth-pg02.jpg
Hopefully your paint shop can cross reference it from there.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline widing'cuda
« Reply #2 on: September 16, 2006 - 06:26:52 AM »
Thanks! Is thunder blue poly B5 interior color? Only blue I found for interior on Barracuda/'cuda
Offline widing'cuda
« Reply #3 on: September 17, 2006 - 06:35:46 AM »
Found out the the spray YearOne is selling is called MOPAINTand the part number is: CP70MDKBLM They can't sell it to me either as they don't ship paint outside the US. Anyone know the mixing ratio for this paint?
Offline torredcuda
« Reply #4 on: September 19, 2006 - 06:05:11 PM »
I think there was only 1 interior blue so thunder blue ploy must be it.I would try and get a pint or half pint mixed up locally and check the colr match.If you can`t I can try and get the formula from my paint guy.
Jeff
Offline widing'cuda
« Reply #5 on: October 14, 2006 - 06:54:56 PM »
If you could get the correct mixing ratio for B5 interior I would really appreciate it.
Offline AARudy
  • 1970 4-speed AAR---71 Cuda conv----70 Chall 440-6
« Reply #6 on: October 16, 2007 - 01:20:48 PM »
there is more then one blue... there's a different blue on the dash, and the other parts, i am in the middle of figuring out the updated codes for a B5 interior...it is a very difficult subject...stay tuned if you still need help on  this...I am very anal about getting this interior right....so I hope I can help!
Offline widing'cuda
« Reply #7 on: October 16, 2007 - 02:18:30 PM »
Yes I'm still interested. I know there is a different  b5 blue for 70 then in 71-74. So the 70 one is the one I'm most after. But the mixing ratio for any interior B5 is a start  :bigsmile:
Offline AARudy
« Reply #8 on: October 23, 2007 - 12:26:19 AM »
you probably know all of this from reading the above posts...but here's the point im at with my interior too.....
ok, it seems that in 70, there was only one blue listed on interior colors...Thunder Blue Poly (gloss and Suede version)... after trying to cross reference the old Ditzler paint code through DuPont (which is supposed to be exact-BUT was WAY off - looked like black almost) I stumbled upon the website listed above: http://www.tcpglobal.com/aclchip.aspx?image=1970-plymouth-pg02.jpg
this was the missing 1970 paint code page I was looking for...I have them for 71 and 71 shows two different blues on the interior...on this 70 chart you'll only find one #13848 (suede finish)...the gloss version has a different number, but its the same color...Roger Gibson has told me that it is near impossible to get a suede paint anymore, so a dusting technique is needed....
ANYWAY! I ordered a quart of the Tunder Blue Poly, and it sure looks like what I've been searching for... I will shoot this soon, and take pics for you... B5 interior needs an entire website dedicated to the subject...there is nothing out there...  the door panels, kick panels, and console, are kind of a mystery....I'm using Legendary interior bright blue parts...which sure seem like they are correct...now for the horn pad, thats up n the air...it should match the dash...I have heard that "just dashes" restores them the correct blue....???   On the 70 chart you'll see another paint code for consoles (Majesty Blue) listed under Plymouth Valiant...I dont know what this blue looks like yet....
71 charts list a Medium Blue Poly, and Bright Blue Poly....but this 70 chart shows everything painted with one color....just that the headliner mouldings are gloss....the dash, A pillar covers, hinge seat covers, dash corners, etc. are all suede finish Thunder Blue Poly...?!
« Last Edit: October 23, 2007 - 10:05:38 AM by AARudy »
Offline AARudy
« Reply #9 on: October 23, 2007 - 12:28:15 AM »
that website seems like its correct...if your shop can use that old paint code then you should be ok....like I said , DuPont tried to cross it, and it was way off....?? Where are you located again??
Offline AARudy
« Reply #10 on: October 23, 2007 - 12:31:02 AM »
Oh, and by the way, I owe torredcuda for finding that website! I just remembered I saw it on here! haha... :ylsuper:
Offline widing'cuda
« Reply #11 on: October 23, 2007 - 02:59:19 PM »
Thanks for the info. I'm in Norway, north Europe. So I can't use this store as paint is not allowed to be sent out side the US without special permission. So i really need the mixing ratio. But I can try with the color code.
