When you get on the power the pinion climbs the ring gear & the lowest resistance is when the driveshaft is traight with the pinion in the diff , , the leaf springs will "give' under power so by having the pinion nose down 5-7 * it becomes straight as the pinion climbs the ring gear , ideally stopping when straight . Unless you have jacked uop the rear of the car a foot the tailshft anglke should be a very low degree off straight & will not change under power
