Author Topic: Yanking 408 Out  (Read 2358 times)
Offline matt63
Yanking 408 Out
« on: September 17, 2006 - 10:04:14 AM »
After a less than a month of driving the head gasket started leaking coolant badly.  Afte discussions with CP, Cometic and the local engine shop (Bel) I decided to yank the engine as I need to have the deck milled for a smoother surface finish so I can run the Cometic MLS head gaskets.  Hopefully this will be a permanent fix.  I probably should have retorqued the Eddy heads after a few heat cycles but it never crossed my mind.  The guy at Cometic says that retorquing is more of a head mfg's recommendation rather than the gasket mfg's.  At least this will give me a chance to inspect all of my bearings and fix the front gearbox oil leak. :eek4:
Matt in Edmonton
'68 Valiant
Offline GoodysGotaCuda
Re: Yanking 408 Out
« Reply #1 on: September 17, 2006 - 10:09:04 AM »
Wow that sucks, hope it works out for you  :sadwavey:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline moper
Re: Yanking 408 Out
« Reply #2 on: September 18, 2006 - 08:03:29 AM »
As much as it's a PITA, at least you can make sure it's right this time.
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: Yanking 408 Out
« Reply #3 on: September 18, 2006 - 08:20:15 AM »
Re: Yanking 408 Out
« Reply #4 on: September 18, 2006 - 11:55:33 AM »
no fun but it has to be done , at least get it done right now
Offline matt63
Re: Yanking 408 Out
« Reply #5 on: September 18, 2006 - 06:02:58 PM »
Definitely.  I thought I did it right last time!  Live and learn.
Matt in Edmonton
'68 Valiant
Re: Yanking 408 Out
« Reply #6 on: September 18, 2006 - 06:10:35 PM »
I thought I did a few things right the first time too.   :bricks1:  :bricks1:  :bricks1:
Offline moper
Re: Yanking 408 Out
« Reply #7 on: September 19, 2006 - 12:33:36 PM »
Well, sometimes even doing everything right can have issues. You havent really hurt much but your pride, and that can be gotten right back when it's back up and running. It's almost time to put them away in CT anyway.
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
Re: Yanking 408 Out
« Reply #8 on: September 19, 2006 - 04:40:34 PM »
I hope everything is all back together really soon, it stinks to be without your car.  Best of luck!
Offline Dustu
Re: Yanking 408 Out
« Reply #9 on: September 19, 2006 - 04:47:00 PM »
How did it perform ?Would change anything while you are into it? Street motor ?               :burnout:
Offline matt63
Re: Yanking 408 Out
« Reply #10 on: September 20, 2006 - 08:17:48 PM »
The engine ran great.  I was just doing some tuning work.  I won't change anything in the motor but if I had to build it again I would go with H beam rods and JE or Diamond pistons instead of the Probes.  I think I would also stay away from the Magnum style Eddy head and go with the LA/pre-magnum head with the shaft mounted rocker set-up.
Matt in Edmonton
'68 Valiant
Offline matt63
Re: Yanking 408 Out
« Reply #11 on: September 27, 2006 - 09:14:27 PM »
Update - I got the block back from the machine shop after getting it decked for the MLS gaskets.  When disassembling the engine I found that the fuel pump eccentric was loose as the cam snout extension piece keyway was hammered out so I now have to put in an electric fuel pump system.  I also got the heads checked for flatness and they are twisted so those will get milled too.  It better run good after this!
Matt in Edmonton
'68 Valiant
Re: Yanking 408 Out
« Reply #12 on: September 27, 2006 - 11:08:44 PM »
It has to run better !!
Offline BARACDA
Re: Yanking 408 Out
« Reply #13 on: September 27, 2006 - 11:32:40 PM »
I would have to agree with you on the re-torqueing.  I have only had two alum headed motors and both have needed retorqueing periodically.  Both heads were Edelbrocks (one a BBC SuperVictor and one a 340.
jim
Offline moper
Re: Yanking 408 Out
« Reply #14 on: September 28, 2006 - 08:04:24 AM »
It sounds mean, but I always smile when I find stuff wrong. It's vindication that you are now moving forward, instead of spinning your wheels. Take the time, get things right, it will be fine when you're done. (the electric system is a better way to go now-a-days anyway :bigsmile:)
