Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Starter Problems
« previous
next »
Print
Pages: [
1
Author
Topic: Starter Problems (Read 1277 times)
Madmax440
Sr. Member
Starter Problems
on:
September 17, 2006 - 12:28:13 PM »
I am having problems starting the car once the car has been running for more than an hour. I have put a new reduction starter, but the problem persists. The car is definately charging and there is plenty of juice in the battery. Should I put some kind of heat shield on it or what
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Starter Problems
Reply #1 on:
September 17, 2006 - 12:31:17 PM »
it may need a heat shield or the timing at idle could be too far advanced
Logged
EVIL72
Sr. Member
Reply #2 on:
September 17, 2006 - 12:57:05 PM »
How do your battery cables look? And are the connections clean? Cables are really cheap and if there the original ones I'd replace them anyway.
Good luck with it.
Logged
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #3 on:
September 17, 2006 - 01:17:10 PM »
Do you have headers? If so, the heat could be getting to the starter. A heat shield around it would help. Also, as was mentioned, this could be a timing issue.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
Madmax440
Sr. Member
Reply #4 on:
September 18, 2006 - 05:41:05 AM »
Will try putting the timing light on it this week. Although, Yes - The headers are wrapped around the starter. So if that doesn't solve the problem will have to go with heat shield. Thanks.
Logged
Madmax440
Sr. Member
Reply #5 on:
September 19, 2006 - 07:44:48 PM »
The problem just got worse. Tonight, it was just clicking when I tried to start it and battery was very low. I got a hot shot (what an embarrassment) and on the way home I tried turning on the headlights and it started to die out. Then died out completely driving up my road and jus short of the garage.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #6 on:
September 19, 2006 - 09:21:45 PM »
so your charging system is not working , the starter may not be a problem
Logged
Madmax440
Sr. Member
Reply #7 on:
September 21, 2006 - 07:11:08 AM »
Problem solved (Picture me kicking self in the A&#), I didn't put the wires onto the starter tight enough and over time from hitting bumps or whatever, they were a loose and arcing
on the headers.
Logged
MEK-Dangerfield
C-C.com Expert
Reply #8 on:
September 21, 2006 - 09:46:53 AM »
Logged
tactransman
Sr. Resident
1973 Challenger- Member here since April 14, 2006
Reply #9 on:
September 21, 2006 - 03:29:47 PM »
Logged
Terry
-tactransman
Union, Mo.
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Starter Problems
