Author Topic: Oil  (Read 1055 times)
Offline Gurragas of Sweden
    • Restorers
Oil
« on: September 18, 2006 - 10:40:02 AM »
What oil should i use in a dana 60??
Re: Oil
« Reply #1 on: September 18, 2006 - 11:32:49 AM »
I would use 75-90 synthetic
but the factory used 80-90w crude based with a friction modifier for the sure grip
Offline trouble
Re: Oil
« Reply #2 on: September 18, 2006 - 06:44:40 PM »
 :clueless: Can you explain what is a friction modifier?
Thanks Al
Re: Oil
« Reply #3 on: September 18, 2006 - 10:49:58 PM »
it is called posi / sure grip additive
 it makes the oil more slippery so the clutches will not grab & chatter
    • Restorers
Re: Oil
« Reply #4 on: September 19, 2006 - 08:06:59 AM »
Like this?
Where can i buy it ?,did you have some good site for that, thank you!
Re: Oil
« Reply #5 on: September 19, 2006 - 10:15:07 AM »
Mopar sells it , Most parts stores will have it also , they usually carry the GM version which is the same stuff
    • Restorers
Re: Oil
« Reply #6 on: September 19, 2006 - 10:58:16 AM »
OK, thanks.
See if i can found it here in Sweden.
