I don't think I'm crazy so here it goes.
I finally found my timing light and for ha ha's decided to check the engine. It has been running fine with no problems but again wanted to check. From what I found out, it was running at 24* total. I advanced it to 34* total, but the weird thing is that it is running 34* all the time, idle to 6000rpm. SO here's my set-up, again it is running fine and I know how to use the timing light, so I thought.
MSD Pro Billet dist. (no vac. advanced)
Holley Street Annihilator Ignition
TO get the mark on " 0 " , I had to dial 34* into the timing light at idle (780 rpm), then when I revved the motor, the mark moved off zero (if I recall the mark jumped up to the right) but quickly returned w/o moving off zero while I revved up to 6000. Is this normal for this set-up? Like I said before never had a problem, did this and now I basically just want to understand.
