Wow. This is getting to be more of a project than I anticipated. Thanks for your answers. This isn’t going in the Barracuda, so I don’t think I’ll go crazy with it. If I stick with just 3 clutches, will retaining the wavy snap ring still be problematic?
My springs look like your shorter ones, but are a little bit longer a 1.375” It only had 11 of them in it. According to the TIN chart you posted, the donor tranny is from a 1984-85 318 van or 2wd Ramcharger. I don’t know if it had ever been rebuilt, but when I put it in a 1975 318 van it ran beautifully. (The same could not be said of the 318, but it did get me from Dallas to NYC so I should quit complaining.)
Basically, it’s going behind a 383 that is quite healthy. (flat top pistons that are flush with the deck, 906 heads, headers, single plane intake, and an unidentified hydraulic camshaft that sounds like rocks in a tin can at idle.)
I plan on keeping it automatic, but have a Transgo TF-2 shift kit in my possession that will likely find its way into the valve body.
All things considered, could I get away with the three clutches and 11 springs?
