Race/Performance Parts
Author Topic: Race/Performance Parts  (Read 3477 times)
Offline HookedOnMopars
  • MOPAR Maniac!
« on: September 20, 2006 - 11:34:21 AM »
New Autometer 5" Tach W/Shift Light 0-8,000 RPM $80
New MagnaFuel Quickstar 300 Fuel Pump $300
MSD 6AL & Blaster 2 Coil $175
NEW MSD Digital 6 & Blaster HVC Coil $350
CSI Transmission & Flexplate Shield $125
INDY SR Heads w/Valley Tray & Oil Lines
Heads have had mild port job and only 4 runs on them. $1,600
Contact Dan @
(501)425-1174
beepbeep70@centurytel.net
« Last Edit: September 20, 2006 - 01:19:11 PM by HookedOnMopars »
Offline EvilTwinATX
Re: Race/Performance Parts
« Reply #1 on: September 20, 2006 - 12:39:50 PM »
is the CSR SHield for  727 Big Block? if so then I am interested.
 :useless:
Offline Morris'_Mopars
« Reply #2 on: September 20, 2006 - 01:07:41 PM »
What color face on the tach? :dunno:
Morris' Mopars LLC
Raymond, Illinois
Mopar performance at affordable prices.
  • MOPAR Maniac!
« Reply #3 on: September 20, 2006 - 01:20:20 PM »
 :useless:
Shield is for a 727 Big Block.
  • MOPAR Maniac!
« Reply #4 on: September 20, 2006 - 01:20:56 PM »
Face is Black.  I just added pics to the original post.
Offline 1BADFISH™
« Reply #5 on: September 20, 2006 - 01:22:23 PM »
Do you take Paypal?
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
  • MOPAR Maniac!
« Reply #6 on: September 20, 2006 - 02:14:47 PM »
I take paypal, but I will first need your zip for shipping & you will need to add 3% for PayPal fees.
Offline 1BADFISH™
« Reply #7 on: September 20, 2006 - 02:19:46 PM »
I may be interested in the tach but don't need it right away, so i'll give someone else a few days to bite if they need it.
 :thumbsup:
Charlottetown, PE
Offline asm74
« Reply #8 on: September 20, 2006 - 02:31:12 PM »
What are the specs on the fuel pump?  GPH, PSI, fitting sizes...
thanks
73 Challenger
  • MOPAR Maniac!
« Reply #9 on: September 20, 2006 - 02:51:01 PM »
thanks
QuickStar 300:
Horsepower Range: Up to 900HP
Amp Draw: 12A @ 28psi, 18A @ 36psi
Bypass: Adjustable from 25-36 psi
Free Flow Rate: 84 gph
Maximum Pressure (psi): 36 psi
Inlet Size: -10 AN
Inlet Quantity: Single
Inlet Attachment: Female threads
Outlet Size: -10 AN
Outlet Quantity: Single
Outlet Attachment: Female threads
QuickStar 300 fuel pumps are built with computer-machined aluminum bodies. They feature MagnaFuel's custom-built motor and exclusive vane/rotor design to provide cool, low-amperage operation without overheating. Compatible with gasoline and alcohol fuel, these pumps use an externally adjustable bypass to eliminate pump cavitation, stabilize fuel flow, and eliminate fuel starvation. They feed engines up to 900 hp, and are great for turbo, supercharged, or nitrous assist setups.
Offline EvilTwinATX
« Reply #10 on: September 20, 2006 - 05:23:19 PM »
Hooked.. looks a lot diff than the CSR they sell at Summitt, etc.. got a part#? any tunnel mods needed for the shield to fit or is it a bolt-in?
Thanks!
Offline moper
« Reply #11 on: September 27, 2006 - 06:55:26 AM »
Why were the Indy heads pulled?
  • MOPAR Maniac!
« Reply #12 on: September 27, 2006 - 05:44:49 PM »
I decided to go with 440-1's instead.
  • MOPAR Maniac!
« Reply #13 on: September 28, 2006 - 05:52:38 AM »
I also have two Radiators for sale:
26" Aluminum Radiator w/Fan
26" Mopar Radiator w/Fan Part # 2949 055
« Last Edit: September 28, 2006 - 05:54:24 AM by HookedOnMopars »
Offline DodgeFreak
  • Cars and trucks are my friends..
« Reply #14 on: September 28, 2006 - 11:42:52 AM »
how much for the rads?
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
