Author Topic: Chally won't turn over  (Read 1023 times)
Offline r15303
« on: September 20, 2006 - 07:37:41 PM »
I Removed my wiring harness last week to clean it up etc. and now I have to move the car.  I put the harness back in along with the steering wheel - hooked up the steering wheel harness and went to start the cat - nothing!  I also took out the inst. panel and all the instruments.  Do I have to connect the amp meter wires together (since the amp meter is removed) to complete the starting circuit??  If I remember my H.S. electricity class - the amp meter is in series with the circuit and if not connected, the circuit will be open.  what do you folks think???
Thanks
Offline 422STROKER
  • Member Since 6/3/06
Re: Chally won't turn over
« Reply #1 on: September 20, 2006 - 07:39:00 PM »
You need the amp meter wiring connected.  Make sure you disconnect the battery first.
Tom
Tom
Offline r15303
« Reply #2 on: September 20, 2006 - 07:41:17 PM »
WOW!!
Thanks for the quick return!!  Any other guages or wires to connect to get it started??  That's really all I need to do at this point.
Thanks
Offline r15303
« Reply #3 on: September 20, 2006 - 07:44:41 PM »
Was just thinking - do I have to have the amp meter in the circuit or can I just connect the wires going to it together?????
Offline 422STROKER
« Reply #4 on: September 20, 2006 - 07:54:07 PM »
Just nut and bolt it and tape of course
Tom :2thumbs:
Tom
Offline r15303
« Reply #5 on: September 20, 2006 - 08:52:16 PM »
Thanks - that did it!!!
Offline 422STROKER
« Reply #6 on: September 21, 2006 - 04:25:53 PM »
Your Welcome. :2thumbs:
Tom :wave:
Tom
