Author Topic: Horsepower from radiator  (Read 972 times)
nivvy
« on: September 21, 2006 - 01:51:39 AM »
My be cool radiator is rated to 700 hp.......but i am going to order some aluminum heads that might flow more cfm to make more than 700hp...am i going to overheat? or is only when i am on it alot?
8 pack
Offline moper
Re: Horsepower from radiator
« Reply #1 on: September 21, 2006 - 10:37:46 AM »
The radiator ratings are seat of the pants type things. Too much depends on what each engine does on it's own. An engine that runs hot can be from a lot of stuff. I'd say you're fine if your system works well now, knowing nothing about what you're planning.
Offline Dragula
« Reply #2 on: September 23, 2006 - 04:12:59 AM »
Actually, there is a little bit to it because I had a summit rad rated at 350-400hp, and I couldn't keep the car cool no matter what I did. I called BeCool and order a new rad rated at or above 700hp, and I didn't change anything else and it did the trick. In fact, a lot of the time I can run just one of the fans instead of both now. Engine doesn't get above 190* with the new Rad
Offline wart1de
    • Vivah
« Reply #3 on: September 27, 2006 - 09:25:31 PM »
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
Offline 426 pentastar
« Reply #4 on: September 28, 2006 - 08:51:44 AM »
some radiators are verticle and some are horizontal,one will produce more cooling and air flow then the other.
Offline KellysCuda aircard
  • Its good to be blown
« Reply #5 on: September 28, 2006 - 05:00:04 PM »
I have great faith in BE COOL rads, I was having trouble with heat and these guys offered me a money back guarantee, no questions asked. They were correct with the rad size and all my troubles went away.    :blah: :blah:
