Author Topic: Heater Controls Dash Light?  (Read 995 times)
Offline Total BS
  • '71 Carrabuda Baby!
« on: September 21, 2006 - 11:10:58 PM »
Hi gang,
The other night I fired up my 71 cuda and turned on the ralley dash lites. There seems to be one bulb that illuminates the heater/AC controls which clicks on for a minute or two and then clicks off and then back on and off repeatedly.  I would assume that a bulb is either on or off. It definitely is an audible click so I don't think it is the bulb.
Is this connected to some sort of relay that is going bad?  I haven't had a chance to stick my big head in there and look yet as I really don't know what to look for anyway.  Any advice would be appreciated.
Thanks,  Ed
« Last Edit: September 21, 2006 - 11:13:22 PM by Total BS »
1971 'Cuda 383
1970 Chevelle SS LS6
1999 Durango
-New Joisey-
Re: Heater Controls Dash Light?
« Reply #1 on: September 21, 2006 - 11:20:00 PM »
something is not connected correctly, the heater light should just stay on , it may be plugged into the ign key light timer
Offline Total BS
« Reply #2 on: September 22, 2006 - 08:40:10 PM »
THanks Neil,
The body shop came and picked it up today so it will be a while before I have a chance to check.  WOO HOO final paint coming up!
1971 'Cuda 383
1999 Durango
-New Joisey-
« Reply #3 on: September 23, 2006 - 12:14:38 AM »
 :2thumbs: :ylsuper:
Offline 426 pentastar
« Reply #4 on: September 26, 2006 - 02:20:09 PM »
The hearter control light makes its ground through the screws that holds the switch panel in at the bottom,sounds like a bad ground.
Offline Total BS
« Reply #5 on: September 26, 2006 - 07:41:09 PM »
426,
Thanks for the reply.  It definitely sounds like that could be the culprit.
1971 'Cuda 383
1999 Durango
-New Joisey-
