Author Topic: E Brake Release Handle?  (Read 571 times)
Offline CUDA JAS
  • vroooooom!
« on: September 23, 2006 - 01:19:06 PM »
Where can I find the little plastic grommet that holds the release handle in place. Mine is broken, and it always ends up on the floor.
The handle does not come off of the mechanisim, but does not stay where it is supposed to.
Thanks,
Jas
74 'cuda 360/727
Just call me a gearhead!
Re: E Brake Release Handle?
« Reply #1 on: September 23, 2006 - 01:58:49 PM »
If your asking about the Emergency Brake Release Handle, mine is t-shaped black plastic on a round metal rod, has a small round hole with what appears to be a metal roll pin holding it in place. Roll pins are common hardware store items. Use a drill bit to determine the diameter of your hole if you have this setup.
« Reply #2 on: September 23, 2006 - 07:44:11 PM »
I have not found a good source for the plastic grommet / spring retainer , I need to cruise the assorted nylon plugs to see if I can find a decent fix
