Author Topic: The Clowns Challenge----r  (Read 17892 times)
RedLine
Re: The Clowns Challenge----r
« Reply #30 on: October 06, 2006 - 10:10:01 PM »
MR Clown-man  -  I need surgery to unlock my jaw after seeing those pics.   :22yikes:  You are a brave man.
Offline moparclown
« Reply #31 on: October 08, 2006 - 08:09:38 AM »
Thanks Redline,I still have shock episodes myself.But I can see it done and I just have to make it happen.I haven't done anything to it lately because I have been working on the 69 cuda.The Clown
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #32 on: October 08, 2006 - 05:07:21 PM »
I think this is the closest to a body-off resto I've seen on a uni-body car  :thumbsup:
Good luck clown
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline RUSTY Cuda
  • One big step foward!
« Reply #33 on: October 08, 2006 - 06:50:43 PM »
I will never again CRY when I pull a piece off a car & find yet another  2x3 patch I have to make, I though mine was to far gone(way worse than I really wanted to deal with on my first resto) being a lowly clone (of a 360 yet) but like you I'm in it for the building, however it turns out I did 95% of the work myself & will be somewhat proud of it, kudos to you MR Clown thats great stuff ! Rich.
Offline moparclown
« Reply #34 on: October 08, 2006 - 08:02:08 PM »
Thank you,and I just want to say I am really impressed by the people on this site that take on some huge work because they want a car and nothing stops them.I hope to meet at least some of you but feel I already know some of you by what I see going on in your garages,or car ports,or driveways.My work will have to come to a stop in a couple of weeks,old man winter will be knocking on my door and since there is no heat in my garage I will shut down till spring.So to all of you keep on going if you can and make sure you post plenty of photo's because I really enjoy this section.And remember you only get one shot at this life so no coulda,woulda,shoulda's, if you want it--do it--------------------------------The Clown
Offline MOPAR FANATIC
« Reply #35 on: October 09, 2006 - 02:57:23 PM »
Nice pics, clown!
Amazing that you can do all that work AND keep this post updated!
Nice shots if the cowl.  I think I know where mine is leaking now from the mouse house!  :stomp:
:2thumbs: Check right above the brake pedal from the floor pan to the firewall. the factory never pinched these together and it may be where your leaks coming from.  :cheers: ---dave---
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #36 on: October 09, 2006 - 09:36:45 PM »
Sounds good!  Time to crawl under the dash!   :working:   :thumbsup:
Offline sccarts1
« Reply #37 on: October 13, 2006 - 08:31:04 PM »
i did exactly the same thing with a 70 cuda. i hope your motive is self satisfaction because bythe time you are done you will find that you could buy one finished for the same or even less $. the difference with mine was the cowl, firewall & tail panel were far worse & need total disassembly but i caught a break with rear floor pan area thanks to a very leaky trans that coated the under carriage with grease. i.ll post some photos soon.
mopar on brother.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #38 on: October 14, 2006 - 07:58:30 AM »
Clown I used to use a 30K BTU Propane heater in my detached garage.  Made it bearable and the propane burns pretty clean so no major CO.  You could by  $20 detector just in case.  It would heat it up in @15 min.  Just a thought :dunno:
Tom :2thumbs:
Tom
Offline SilverChally
« Reply #39 on: October 14, 2006 - 11:55:56 AM »
We use an old wood burner and its a 4 car garage, not sure actual size, its gets over 80 degrees in there, actually way too hot!
Winter is my favorite time to work on em, so get some heat and no excuses! :cheers:
70 challenger project
68 satellite
Offline Madmax440
« Reply #40 on: October 14, 2006 - 12:18:55 PM »
You are better man then I for keeping this one from going to its final resting place. I would have had to just let it go.
Offline highspeeddirt
« Reply #41 on: October 15, 2006 - 09:15:08 AM »
This would be like stopping a good action movie right in the middle, and waiting till spring to start again.  Could there be a "Heat the clown garage" donation in the making?  Someone might have an extra heater they're not using for example?  If I had one I'd give it up.  I miss my cuda, and your intesive work is very inspiring and gives me hope for another one no matter what the condition it may be in. Heck, you get me even thinking about hounding the guy to death about the basket case I originally found.
  Keep up the awesome work!  :2thumbs:
Butte, MT
Offline 4Cruizn
  • HEMI FISH
« Reply #42 on: October 15, 2006 - 11:30:37 AM »
The winter is when I get everything done as it's too cold to do anything outside . . buy alittle heater clown!!  I have alittle propane deal that works off the bar-b-que tank.  With my insulated garage . . I stay pretty warm!
Offline JCWCuda
« Reply #43 on: October 15, 2006 - 11:36:45 AM »
I snagged an old Oil fired hot air furnace from my parent when they went newer . I run it off KERO and it keeps the barn TOASTY  :2thumbs:
1974 Barracuda 360
2008 Ram 1500 Quad Cab 5.7l Hemi
1990 Jeep Cherokee 4.0l
Gone but not forgotten
1967 Barracuda 273
1976 Charger 318
2003 Dakota Quad Cab 4.7l
1988 Jeep Cherokee 4.0l
Offline 422STROKER
« Reply #44 on: October 15, 2006 - 03:22:43 PM »
Imight have something you can use.  I have a 100-200K btu barrel heater that needs a 100lb tank to run properly(full power) it's too much for the jobsite but you could use it in the garage for a few minutes at a time to take the chill out.  Let me know and we could prob work something out cheap.
Tom :2thumbs:
Reading MA
Tom
