Author Topic: engine problems  (Read 1945 times)
Offline Nate10
Re: engine problems
« Reply #15 on: September 26, 2006 - 03:35:00 PM »
this is the carb but I dont have the shinny one just plane aluminum
http://www.holley.com/0-80508S.asp
Offline Nate10
Re: engine problems
« Reply #16 on: September 26, 2006 - 03:44:23 PM »
As far a the torque converter goes I called TCI and they said it has a 1700-1900 stall and stock to 3.23 gear and stock to 265 degrees. I hope this helps a little, thanks for all your replies I am defently learning alot.  I looked up cams on summit racing but could not find the Engle K56.  I think after all the research that the cam is the wrong one. Yes, No?
Re: engine problems
« Reply #17 on: September 26, 2006 - 04:24:41 PM »
Nate,
  You are doing well here in providing info.  :thumbsup: The cam you have is too large, no doubt. Your torque converter is too small to fit it. As we feared, you have some mis-matches in your setup. Basically, your rear is locking up before your cam even reaches it's power band. That's why it is a dog. You would do better with a mild cam with a slightly higher rated torque converter.
« Last Edit: September 26, 2006 - 04:29:29 PM by MEKrunner »
Re: engine problems
« Reply #18 on: September 26, 2006 - 10:25:42 PM »
www.englecams.com
 the carb & intake are good choices
 the cam sounds like a problem , it would still be good to get specs if possible
Offline moper
Re: engine problems
« Reply #19 on: September 28, 2006 - 10:43:25 AM »
Nate, a compression gage is $10 at almost any local parts store. Go buy one, pull all 8 plugs with the engine hot, block the carb at full throttle(wide open), and take a reading from each cylinder. have a squirt can of oil handy, and after each "dry reading" pump a squirt or two in the cylinder, and retest. Write down the dry and wet for each cylinder on a scrap of paper. If the readings are more than 10% varied from the lowest to the highes,I wouldnt put any money into it until you figure out why. If they are all close, but low (say under 120psi), the cam may be ok sized, but not in right. Or there could be a mechanical reason like bad timing chain, oil pump drive, etc. causing it. Your choice at that point is fix what you have, or just buy what you think will work. I've rescued a bunch of lazy engines by simply degreeing the exisiting cam and putting it back together. Most shops do not degree a cam unless you tell them to.
