Your brake booster lives on vacuum so higher revs drops the vac, that's not the issue. Different tire diameters will effect braking, have you put much larger tires on the rear than front? Adjustable proportioning valve would be the answer if so. Earlier when I first read your post made me think of similar problems some friends had back when they used to put air shocks on & jack up the back changing the balance more to the front.
