Author Topic: Fluid Capacity  (Read 2452 times)
Offline basement
Fluid Capacity
« on: September 25, 2006 - 01:08:26 PM »
Would someone tell me how many bottles of 90w gear lube I'll need to refill my 4-speed manual. Sorry, not sure of what tranny I have, just need a ball park so I know how many to pickup on the way home. While I'm under there how would I be able to tell what model transmission it is?
Re: Fluid Capacity
« Reply #1 on: September 25, 2006 - 01:14:38 PM »
book says 4 speed A-833 takes 7.5 pints "DEXTRON" type automatic Transmission fluid.   Thats from a '73 Dodge Chassis Service Manual  :clueless:
Offline GoodysGotaCuda
Re: Fluid Capacity
« Reply #2 on: September 25, 2006 - 03:29:00 PM »
3speed calls for 4.7 pints, 4speed says 7pints. why would it take ATF, theres nothing hydraulic in there which would require hydraulic fluid...
« Last Edit: September 25, 2006 - 10:55:17 PM by GoodysGotACUDA »
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: Fluid Capacity
« Reply #3 on: September 25, 2006 - 06:57:59 PM »
Just to be sure I went to the AutoZone site as they have lots of teck stuff on line & this is what the 4-speed selection provided
 Home
Transmission Fluid Type
For your 1973 Dodge Challenger:
SPEC-FLUID-TYPE/WT AF Dexron III
Optional:                                              GL-4 or GL-5 gear oil 75W, 75W-80, 80W-90, or 85W-90        may be used for warm weather operation
Lubrication Hotline
Call 1-800-373-LUBE (5823) for technical information  on engine oil, gear oil, grease & transmission fluid. Open monday through friday 8AM to 5PM central time.
Re: Fluid Capacity
« Reply #4 on: September 25, 2006 - 10:23:39 PM »
I have used ATf in winter driving but for summer I use 75-90 or 80-90 GL4 , 4 qts / 1 gal is needed
Offline basement
Re: Fluid Capacity
« Reply #5 on: September 26, 2006 - 07:23:44 AM »
Boy, when I drained the old fluid last night I thought someone had used mud to fill it with. It was way, way over due. Thanks for all the responses. I love this site, it's like having your own online service manual.
