Author Topic: 727/518/618 case cut for a JW ultra bell - update  (Read 20747 times)
Offline ntstlgl1970
  • T a c o c a t
Re: Anyone cut a 727/518/618 case for a JW ultra bell?
« Reply #30 on: May 02, 2007 - 09:53:58 PM »
The case is cut, here are the pics, fits the block nice!
cummins 47RE + JW ultra bell =  :thumbsup:
« Last Edit: December 17, 2008 - 04:32:28 PM by ntstlgl1970 »
Offline tactransman
« Reply #31 on: May 03, 2007 - 07:07:52 AM »
 :clapping: That is a very strong looking bell housing. :grinyes:  Was it hard and time consuming to get it to fit?
Terry-tactransman
Union, Mo.
Offline ntstlgl1970
  • T a c o c a t
« Reply #32 on: May 03, 2007 - 11:25:16 AM »
Maybe a total of 2 hours after I figured out which sawzall blade worked the best. The final touches I did with a flap wheel on an angle grinder. I still need to check concentricity and everything, but it locates very well. The bellhousing is SFI approved as well. The flange at the trans and engine is around 9/16 - 5/8" thick and the rest is around 1/2".
Offline tactransman
« Reply #33 on: May 03, 2007 - 11:35:51 AM »
What centers it on the front of the case?
Terry-tactransman
Union, Mo.
Offline ntstlgl1970
  • T a c o c a t
« Reply #34 on: May 03, 2007 - 03:30:39 PM »
The bore for the front pump in the case, there is a taper machined into the bellhousing to front pump flange OD that centers it in the hole. I'll still measure to be sure though.
Offline ntstlgl1970
  • T a c o c a t
« Reply #35 on: May 21, 2007 - 05:44:57 PM »
Just some update pics, got the dummy engine and the trans case in the car for mock up....some detail photos....
I wasn't expecting to have to cut the passenger side of the tunnel, but maybe that is due to the extra webbing on the low/reverse servo area on the 47RE, not sure.
« Last Edit: December 17, 2008 - 04:35:47 PM by ntstlgl1970 »
Offline tactransman
« Reply #36 on: December 16, 2008 - 03:11:21 PM »
Ah crap,the pics are gone!
Terry-tactransman
Union, Mo.
Offline dtedler
« Reply #37 on: December 17, 2008 - 04:21:12 PM »
Don't be afraid of bing the "pig" for Quick Time.  Ross is a stand-up guy and he worked very well and very efficiently with us to get the big block to TKO bell housing completed.  His products are excellent quality which comes from having excellent equipment and the strong understanding of metal spinnings.
Tony Edler
Classic Mopar 5 Speed
Offline ntstlgl1970
  • T a c o c a t
« Reply #38 on: December 17, 2008 - 04:22:51 PM »
Tony Edler
huh?
Offline tactransman
« Reply #39 on: December 17, 2008 - 04:30:41 PM »
Tony Edler
This is on the wrong thread. Should be this one.
http://www.cuda-challenger.com/cc/index.php?topic=52778.0
Terry-tactransman
Union, Mo.
Offline ntstlgl1970
  • T a c o c a t
« Reply #40 on: December 17, 2008 - 04:36:29 PM »
replaced the pics that disappeared
Offline tactransman
« Reply #41 on: December 17, 2008 - 04:44:23 PM »
 :clapping:
Terry-tactransman
Union, Mo.
Offline Tubbed440
  • Suspension NinJa
« Reply #42 on: December 18, 2008 - 08:34:30 AM »
Good info man. Thanks.
74 Dodge Challenger
500 inch stroker, Full cage, ladder bars,
coil-overs, 4L80E, 325/50 M/T DR's....street car!
(work in progress)
Offline ntstlgl1970
  • T a c o c a t
Re: 727/518/618 case cut for a JW ultra bell - update
« Reply #43 on: February 07, 2009 - 06:32:52 PM »
well I'll just say CRAP!
looks like my trans case was damaged when the front band anchor let go, either the band end or the anchor looks like it took out the pump inlet/return opening in the casting. I didn't catch it until I went to start assembling the trans today. This sucks. Guess I'll be looking for another donor trans. Maybe I'll get lucky and find one cheap again. I don't think a lot of guys are looking for a V10 47RE trans.
I'll post pics in a little bit....
Offline ntstlgl1970
  • T a c o c a t
« Reply #44 on: February 07, 2009 - 06:49:18 PM »
right above the 61/64th's mark on the scale is one crack, there is another near the opposite corner nearest the valve body opening. something got shoved into the casting to break it like that. Glad I didn't run it in the car. Would have been hard to hunt down.
