Author Topic: Vibration  (Read 972 times)
Offline moparnut
    • My Photo's
Vibration
« on: September 28, 2006 - 08:37:31 AM »
WHat would cause some vibration being felt in the steering colum?
thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline moparnut
    • My Photo's
Re: Vibration
« Reply #1 on: September 28, 2006 - 08:38:10 AM »
oops it feels like its coming from the engine
Offline 426 pentastar
Re: Vibration
« Reply #2 on: September 28, 2006 - 08:49:09 AM »
Normally if you feel it in the stearing wheel its the front end[stearing box lose??]ider arm and so on.If you feel it in the bottom of your pants then its drive train
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Re: Vibration
« Reply #3 on: September 28, 2006 - 08:49:30 AM »
Bad alignment.  Unbalanced wheel.  Bad wheel bearing.  Bad tie rod.
There are more possible causes.
Is this something you feel at idle?  If so, could be a bad motor mount, or clearance problems with you exhaust.
Offline moper
Re: Vibration
« Reply #4 on: September 28, 2006 - 10:44:42 AM »
Moving or sitting still? in gear or idling in nuetral? does it speed up and slow down with the engine, or with vehicle speed?
Offline moparnut
    • My Photo's
Re: Vibration
« Reply #5 on: September 28, 2006 - 06:43:02 PM »
sorry i should have been clearer.It does is at idle and a little faster when you rev the engine
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Vibration
« Reply #6 on: September 29, 2006 - 01:36:39 AM »
That sounds like it could be something with the motor.  Did you have the motor balanced before you installed it or is it original?  Is it possible that your damper has spun a little causing it to become unbalanced?
Really need more info.
Offline Hemi Challenger
  • Nothing run better then a HEMI
Re: Vibration
« Reply #7 on: September 29, 2006 - 06:28:05 AM »
I'm not an Expert but it could be a Bad Pilot bearing or a number of thing like everyone has said   :banghead: you are going to be   :pullinghair: until you find it or you are going to have to live with it
Offline moparnut
    • My Photo's
Re: Vibration
« Reply #8 on: September 29, 2006 - 08:01:16 AM »
I really wasnt too worried about the vibration since the car probably wont get driven much until its gets restored(after my GC is done)but as wondering why.The previous owner did say something about not taking the balancer/flyhweel in when they rebuilt to motor after i pressed him on the rebuild(rookie move but he didnt know any better,probably thought it was a forged crank but is cast in 73 since its the original motor)I thought it might be something easy to fix.Its only real bad when the idle is set too high and seems to run fine when driving.
thanks
Offline moper
Re: Vibration
« Reply #9 on: September 29, 2006 - 10:07:00 AM »
If it is gone when driving, I'd say it's a tuning issue. Maybe a weak cylinder or bad wire. A forged crank convertor, and cast crank will rattle your fillings loose at 3K rpm, whether or not there is a load on it.
