Author Topic: 440 water pump housing  (Read 1239 times)
Offline 71chmark
« on: October 02, 2006 - 03:08:10 AM »
I bought an aluminum water pump from mancini and after looking at my housing and busting a few bolt heads I decided to get an aluminum housing too. The pictures of the aftermarket housings look different then mine. Must be something I don't know?
I may be schizophrenic,
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
Re: 440 water pump housing
« Reply #1 on: October 02, 2006 - 05:15:53 AM »
One is for AC cars, the other is for non AC.
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline Plum6Pak
  • Plum6Pak
« Reply #2 on: October 02, 2006 - 05:33:17 AM »
Your old one is for a right side suction, the one in the picture is the left suction type. I believe that trucks used the RH suction but not positive. If you use the one from Mancini you will need to make sure your radiator is setup that way as well. All the big blocks including 426 hemi share the same water pump housing.
Offline 71chmark
« Reply #3 on: October 02, 2006 - 10:42:48 AM »
Great.  I have two 26 inch radiators with the bottom connection on the passenger side. Guess I'll just try and salvage my old housing. Thanks for your input.
« Reply #4 on: October 02, 2006 - 11:33:50 AM »
the right side pump that you have was used 73 & up on all applications , the left side was the early style 72 & earlier
Offline 71chmark
« Reply #5 on: October 02, 2006 - 03:06:24 PM »
Thanks. I suppose I can still get a 73 & up somewhere.
« Reply #6 on: October 02, 2006 - 08:33:48 PM »
I have never seen or heard of an alum version of the right side housing
Offline EvilTwinATX
« Reply #7 on: October 11, 2006 - 03:57:02 PM »
« Reply #8 on: October 11, 2006 - 10:50:46 PM »
iron housings should be relatively easy to get from a wreckers
