So it's already being driven then? Do you have any track times for it? That cam is what i'd classify as a medium size for a 3.75 stroke. You say it's 0 deck, what head gasket, and was the compression verified by measuring stuff? You can gain drivability by adding compression with any cam design. With modern heads, and good pistons, you can get up close to 11.25:1 and be safe from detonation with careful tuning. As to the swapping to roller...I wouldnt sepnd the money on a hydraulic roller. They are limited because of the nature of a hydraulic lifter, and the flat tappet performance cams are very similar to them, just a little smoother, and a little more power. But the power comes from lost friction, not really the cams making more..just not using as much. Solid rollers can be installed, but they are more money, and if it was done thru me you would have to bush the lifter bores. Typical costs are in the $1600 range when everything is said and done, and that's when the engine is being rebuilt. So to reftrofit, you'd have to pull it all apart. So add freshening costs to that (another $3-500). Typically, cams work like this. Hydraulics run quiet, need careful setup, and are maintenance free once put in. Solids need lash adjustments (roughly once a summer), require different pushrods and rockers, and again need careful setup, but make more street type power (torque and better idle for similar sized grinds) than the hydraulic. Rollers need the same 1-2times a summer lash adjustment, lifter bushings, pushrods, rockers, valve springs, oil pump drive, and the cam core and lifters are 3 times the cost of the flat tappet designs, but give the smoothness, idle quality, and both street and race type power (torque, idle quality for given size, and pull to high rpms very easily). If it were me, I'd upgrade to 11:1 static compression, and run a solid flat tappet cam if you are looking to improve. But, back to the first question...What does it run now? MHP in the 1/4 is the best wqay to see if it's doing what it should be now. Perhaps there are things to tweak. I'd think that engine in your car, with good tires, should be running at least high 11s, with mid 11s within reach. Thats about 490-510hp give or take.
