Well, I worked on the car again today. I took the advice of the members that posted up and went to the parts store first thing and bought a starter relay, and new battery cables. I put those on, cleaned up all of the connections, and checked out my voltage and resistance with the voltmeter, then I changed the oil and filter. Now the moment of truth....I get in the car and turn the key. Nothing happened. Then I realized that I forgot to put one of the wires back on the starter relay. Put that back on, and crossed my fingers. I hit the switch and I heard the starter engage but it wouldn't turn the motor over. So I had to unbolt the header, drop it out of the way, take the starter off, and go to the parts store to get a new one. I get back, put the new starter back on, bolt the header back up and try again......it does the same thing.....click click click. I go back to the shop to get a 1/2 drive pull handle, and a socket to turn the motor with by hand. I turn it a few times....double check all of my wiring, and get back in the car. The motor finally turned over!!!! It didn't hit a lick though. So, after a few minutes of trying to crank it, I got out, and rotated the distributor clockwise(facing the front of the car) about a 1/4 turn. I put some more fuel in the carb, got back in the car, and turned the key. It finally hit!!!!!!!!!!!!!!!!
I ran a fuel line into a small gas jug hoping that the fuel pump would pick up some fuel so that it would run. It didn't
So, I put some fuel in the carb a few more times to hear it run...music to my ears...and I called it a day. Next time I'm gonna put a new fuel pump on it, and clean out the fuel system. Then maybe I can move on to the brakes and put a decent set of tires on it..
