Fender Tag code quistion; M88
Author Topic: Fender Tag code quistion; M88  (Read 9619 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: October 03, 2006 - 11:11:51 AM »
What does M88 on the febder tag mean. I found two anwser. What is the correct one?
M88 Quarter Panel Tape Treatment
M88 Deck Lid Moulding treatment (was does this mean anyway)
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline widing'cuda
Re: Fender Tag code quistion; M88
« Reply #1 on: October 03, 2006 - 12:12:36 PM »
This is my fender tag decoded at www.stockmopar.com:
D32   H-D A-727 TorqueFlite Trans
E63   383-4 Barrel
BS23   B = Plymouth Barracuda S = Special 23 = 2 Door Hardtop
N0E   N = 383 330HP OR 335HP 1-4BBL 8 CYL 0 = 1970 E = Los Angeles, CA, USA
******   Sequence Number '******'
EB5   Paint Code: Bright Blue Metallic / Blue Fire Irid
H6B5   Trim Grade/Style/Color H = High 6 = Vinyl Bucket Seats B5 = Medium Blue
000   Upper Door Frame: Full Door Panel
B19   Date Built: 11 / 19 / 1969
043329   Order Number: 043329
EB5   Roof Type OR Color:  Bright Blue Metallic / Blue Fire Irid
A62   Rallye Instrument Cluster
C16   Console w/ Buckets
C55   Bucket Seats
G33   Left Hand Outside Mirror - Manual / Chrome
H51   Single Air /w Heater
J25   3 Speed Variable Wipers
J45   Hood Tie Down Pins
M21   Roof Drip Rail Moldings
M25   Wide Sill Molding
M31   Belt Molding 69-70
M88   Quater Panel Tape Treatment
N41   Duel Exhaust w/o Tips
N42   Chrome Duel Exhaust Tips
N85   Tachometer
R11   Music Master Radio AM
26   26 in. Radiator
END   End of Codes
Does this mean my 'cuda came with the strobe stipes or hockey stripes?
« Last Edit: October 03, 2006 - 12:27:28 PM by widing'cuda »
Offline Green Drop Top
« Reply #2 on: October 03, 2006 - 12:28:15 PM »
Quote
...So says the online decoder but it's wrong, it's really for the rear bright trim.
Offline widing'cuda
« Reply #3 on: October 03, 2006 - 12:36:12 PM »
Ok, thanks!
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #4 on: October 03, 2006 - 12:42:14 PM »
M88 on an E-body is rear deck lid (chrome) moulding, M88 on a B-body is the quarter panel tape treatment, this common code for two different trim options on two different body lines IS confusing leading many to assume that M88 on an E-body is the Billboard or Hockey-stick stripe (which of course is V6*), the * denoting the color of stripe.
Offline widing'cuda
« Reply #5 on: October 03, 2006 - 12:51:28 PM »
Ok,Thanks. That explained alot for me  :thumbsup:
« Last Edit: October 03, 2006 - 01:12:47 PM by widing'cuda »
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #6 on: October 03, 2006 - 01:34:42 PM »
For the record a strobe stripe is only availabe on '70 'Cudas after Feb. and only in a few colors, the code is:
V4X: Black strobe stripe (no restriction on body color)
V4W: White strobe stripe (no restriction on body color)
V4J: Chartruse strobe stripe (only available on Sassy Grass cars) only one known to exist
V4M: Magenta strobe stripe (only available on Moulin Rouge cars) only five known to exist
If alternate color options are available let me know but to my knowledge this is accurate.
Offline cjm
  • 70 Cuda - In Progress.....
« Reply #7 on: October 03, 2006 - 05:55:42 PM »
I had asked this question a while back and was told that it was the deck lid moulding treatment as well. I have a 70 cuda that has the m88 code but doesn't have the "deck lid moulding treatment", another member had the same issue. I was told that on a 70, the m88 code (cuda) was for the chrome strip on the tail panel. On later models, m88 is the "deck lid moulding treatment" -- (this is the chrome that is on the edge of the deck lid and also on the back of the quarter panels (where it meets the tail panel))....  I have seen cars on ebay that state that m88 is the 1/4 tape treatment, I don't know where they got that from.........
Offline RusTy/SE
  • Just havin' fun
« Reply #8 on: October 03, 2006 - 08:19:03 PM »
So it would stand to reason that M88 on an E-body could only be a Plymouth as decklid (or quarter) trim was never an option for the Challenger, whether in separate pieces or as part of the rear "SE" trim panel.
Maybe someone has a Dodge E-body with M88 on the Fender Tag? Otherwise seeing one with M88 on the Fender Tag should raise a red flag :nono:
Just a theory :2cents:
Barry, did i get this one right  :thinkerg: :) :thinkerg:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Alaskan_TA
« Reply #9 on: October 03, 2006 - 08:42:53 PM »
M88 as far as E-Bodies go is Cuda only, with one exception, (that I know of) Barracudas with front and rear rubber bumpers came with M88 as well.
In 1970-71 the M88 molding was called "Deck molding treatment".
For 1972-1974 it was called "Deck lid molding treatment", note the difference?
Here are some photos, I do not have one from 1972 to show, but these should help;
Offline 360 'CUDA
« Reply #10 on: October 03, 2006 - 09:49:19 PM »
OK, I have to ask
(please don't tell me the valance is cut out to make room for the spring shackles)
Alaskan_TA
« Reply #11 on: October 03, 2006 - 09:52:37 PM »
I have no clue, I have not seen the car in person. I love the rear tires though.  :thumbsup:
Barry
Offline AARudy
  • 1970 4-speed AAR---71 Cuda conv----70 Chall 440-6
« Reply #12 on: May 17, 2007 - 09:44:59 AM »
Sorry for bringing up such an old topic...but my AAR has M88 on the tag...does this mean I have a rear rubber bumper, or just the trim around the tail panel...I thought front and rear rubber bumpers were only on red cars..or some other color..not blue..?? This just cought my attention after reading this old topic...
I'm assuming it's just the trim..?
Thanks!
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #13 on: May 17, 2007 - 07:10:05 PM »
AARudy, M88 is the belt moulding, A21 is the rubber bumper and can be ordered in any high-impact color not just red.
Alaskan_TA
« Reply #14 on: May 17, 2007 - 07:38:13 PM »
A21 is the front rubber bumper.
A22 is both front & rear rubber bumpers.
All 1970 Cuda's had M88 regardless of bumper style.
1970 Barracudas with front and rear rubber bumpers also got M88.
Barry
