Author Topic: A833 OD  (Read 1189 times)
Offline gichy
A833 OD
« on: October 03, 2006 - 11:36:26 AM »
Well it's time to start working on my OD tranny.
I have a couple of questions?
My bell housing is from a 318 3spd which measures 4.30"
and the OD tranny bearing retainer measures 5.25".
I am going to get the bearing retianer turned down to 4.80"
and try to get the bell en-larged to 4.80"
My question is how acuarte does the machining have be, is there a tolerance I should be shooting for?
Thanks Rich
1974 Barracuda, 340cid, 4 speed OD !!
Re: A833 OD
« Reply #1 on: October 03, 2006 - 10:05:53 PM »
the retainer is easy to size properly , the bel needs to be within a couple of thou & will be harder to cut
 offset dowels can help center it if it is off but you cannot adjust far withthe dowels
Offline gichy
Re: A833 OD
« Reply #2 on: October 04, 2006 - 08:17:35 AM »
Thanks CP
The bearing retainer can be turn down on a lath.
What should someone use for the Bell Housing???? :clueless:
Re: A833 OD
« Reply #3 on: October 04, 2006 - 09:59:06 AM »
Lathe works I cut my retainers down , I have never cut a Bel though , talk to a machine shop
« Last Edit: October 05, 2006 - 09:11:31 AM by Chryco Psycho »
Offline moper
Re: A833 OD
« Reply #4 on: October 05, 2006 - 06:01:53 AM »
I've cut the bell alone before. I went from small block (small retainer) to the OD size. As long as they center off the exisitng opening, you should have no issues. But, you should be checking the alignment anyway to make sure the whole thing works right.
Offline moparnut
    • My Photo's
Re: A833 OD
« Reply #5 on: October 05, 2006 - 08:30:49 AM »
Or as i did you can eliminate all the hassle and its probably going to be the same cost and you dont have to cut the bell or tranny up.Look for the OD bell for the OD tranny(thanks to shelbyDog for finding me one on the net),Chrysler part number 202507,you might as well get the fork too(but it is still available from the dealer)
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline gichy
Re: A833 OD
« Reply #6 on: October 05, 2006 - 09:45:21 AM »
How much did the OD bell cost you?
The machining cost should not be a problem, one of my supplers will most likley do it for free.
Offline moparnut
    • My Photo's
Re: A833 OD
« Reply #7 on: October 05, 2006 - 07:51:46 PM »
I think it was 80 bucks,but i got the flywheel as well for another 30 i think
