Author Topic: 70 Coronet drivetrain into 70 Challenger?  (Read 910 times)
Offline bb71challenger
« on: October 03, 2006 - 08:25:10 PM »
I can get a 70 Coronet 500 4 door for about 200 dollars with a 318 in running condition. I want to use the whole drivetrain in my hunka junka 70 Challenger, will it work? I have heard the B-body 8 3/4 is 1" narrower than that of an E. I know the driveline might have to be shortened but other than that can I bolt the K-member and everything into a Challenger chasis with no major headaches? thanks for any info.  :1zhelp:
*Brett*
Re: 70 Coronet drivetrain into 70 Challenger?
« Reply #1 on: October 03, 2006 - 10:08:39 PM »
everything Should swap , the K frame will bolt in but May have an issue with the angle of the steering box  , you can either use offset mounts to move the springs in na inch or so on each side or reweld new spring seats onto the diff
Offline Challenger6pak
« Reply #2 on: October 04, 2006 - 08:26:08 AM »
Do you have any drivetrain in the Challenger?  The Bbody(Coronet) driveshaft is longer than the Ebody(Challenger) unit. If the Challenger has a V-8 K-frame, you can use it with the Coronet 318.  Everything else will change over. As Chryco said you will need to change a few things to mount the rear into the Challenger.  I use the B rears in the E's.  It is a worthwhile project for tire clearance.
Offline tactransman
« Reply #3 on: October 04, 2006 - 10:51:08 AM »
For driveshaft reference:
Terry-tactransman
Union, Mo.
« Reply #4 on: October 04, 2006 - 07:09:16 PM »
Thanks for the info guys. I have access to the original K-member but it is not what I would call nice looking. I have no suspension whatsoever under the car now. I want to get it into roller shape at least and the coronet is a cheap way to do that. I guess I will go pick up the 318 K-member while I still can. Thanks again for the information.
*Brett*
