Author Topic: Cuda has a vibration  (Read 1041 times)
Offline 71340RT
« on: October 04, 2006 - 08:38:40 PM »
I have been trying to figure out a vibration I have on my Cuda since I started driving it on the road in march of this year. When I drive down the road I start to get what feels like a vibration coming from the rear of the car at about 50 mph. If I push the clutch in when it is vibrating it does not go away. I had all the new BFGoodrich radial TA tires balanced on a road force balancer and the shop told me one of my wheels had a slight bend but that it had balanced fine. I decided that the first thing I would try is to take the bent wheel off and mount a wheel off my Challenger RT and see if it would fix the vibration. I did this today and guess what the vibration went away and this is one of the easiest problems I have ever solved on my Mopar cars. I was ready to have the driveshaft balanced and change out the rear wheel bearings if needed. Hope this will help someone else with a problem like mine fix there issue.
Jeff
« Last Edit: October 04, 2006 - 08:40:53 PM by 71340RT »
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Re: Cuda has a vibration
« Reply #1 on: October 05, 2006 - 12:30:58 AM »
 :2thumbs:
« Reply #2 on: October 05, 2006 - 05:08:10 AM »
Thanks Good to know
Saw that Stockton Wheel Has repair service for wheels.
http://www.stocktonwheel.com/widen_straighten2.htm
Offline moper
« Reply #3 on: October 05, 2006 - 06:03:06 AM »
I had the same pronblem on my dump run truck. I suppose it's just my good luck when buying used wheels and trie from a recycler...lol.
