Author Topic: Boom ----uh oh  (Read 3368 times)
Offline moparclown
Boom ----uh oh
« on: October 07, 2006 - 07:08:00 PM »
Put the trans back in today(904) went for a test drive.Everything felt good came to a stop and took off nice and easy shifted the trans up to second and pow smoke everywhere.Totaly disgusted I locked the doors and walked home,about a half mile.My friend tony grabbed his truck and trailer and we went and hauled the cuda home.I thought that the front pump let go again,but I was wrong.Climbed under the car quick and found the torque converter is split.What would cause this to happen?I shifted the car at 2200 rpm's when it let go.the trans is a 904 with a low gearset and a manual valve body,the converter is a 2600 -2800 stall and only has about 250 miles on it.The confused and frustrated Clown
Re: Boom ----uh oh
« Reply #1 on: October 07, 2006 - 07:52:58 PM »
Man that's the pitts, :eek4: sorry to hear, maybe tractransman will know  :dunno:
Offline tactransman
Re: Boom ----uh oh
« Reply #2 on: October 07, 2006 - 08:23:16 PM »
Man , you have to be getting frustrated. :swear:  I have never seen one crack there. What brand of converter is it? I would almost say someone did a bad build job on the converter. Other than that I would say (even though I have not seen it) that converter fluid pressures were too high. :dunno: If it were a lock up , I would say that someone milled the cover too much where the clutch rides (they do that on a rebuilt L.U. converter to make sure it is flat where the clutch rides), but it is not a lock up , right?
« Last Edit: October 07, 2006 - 08:27:52 PM by tactransman »
Terry-tactransman
Union, Mo.
Re: Boom ----uh oh
« Reply #3 on: October 07, 2006 - 08:35:31 PM »
wonder if the fluid loss th 1st time was the converter?
Offline moparclown
Re: Boom ----uh oh
« Reply #4 on: October 07, 2006 - 08:44:33 PM »
Its not a lock up,and it was made by suncoast.Do you think this could have started with the mishap a couple of week's ago when the fan took out my radiator?could it have ballooned up when the engine hit 7 grand?and now it just split where the metal stretched?I might be reaching on this one but I am really frustrated and would like to know why this happened.And I thank you for any input on this tactransman.If it was ballooned out could that be why the other pump got waisted?----The Clown
Offline tactransman
Re: Boom ----uh oh
« Reply #5 on: October 08, 2006 - 06:22:01 AM »
I thought that this was a new converter since the pump problem. If this converter was the one that was in the car when the pump went out then yes I agree with your theory. I wonder if they used a lock up converter cover for a core, and it was stressed from when it was a lock up. (the covers look the same between LU and NLU)
Terry-tactransman
Union, Mo.
Offline moparclown
Re: Boom ----uh oh
« Reply #6 on: October 08, 2006 - 06:37:52 AM »
Thank you sir,I will try and get the umph to pull this today.Thank god I didnt pull a 6 grand shift,I might not have any feet right now.------The Clown
Offline tactransman
Re: Boom ----uh oh
« Reply #7 on: October 08, 2006 - 06:49:23 AM »
You might want to look into this company for another converter
 http://www.ptcrace.com/index.php?osCsid=3ac3817924cbc159aa574ca1e9926ec1
 I hear alot of good things about them including price. :thumbsup:
Terry-tactransman
Union, Mo.
Offline moparclown
Re: Boom ----uh oh
« Reply #8 on: October 11, 2006 - 05:40:14 PM »
Pulled the trans. out tonight.heres a better photo of the split,should I pull the trans back apart?-----the Clown
sleepychallenger
Re: Boom ----uh oh
« Reply #9 on: October 11, 2006 - 05:50:40 PM »
i would open it up just to check for metal shavings or anything that might of come loose. who knows when that happens. best of luck to you.
Offline tactransman
Re: Boom ----uh oh
« Reply #10 on: October 11, 2006 - 06:58:01 PM »
I would not touch the transmission, by the sound of your story , I don't think you ran it low on fluid.It should be fine. Looks like poor workmanship to me. I would go with another company. I bet they used a lock up cover for a core and it was weak there. :grinyes: Try P.T.C. I think Chryco has one of their converters. :thumbsup:
« Last Edit: October 11, 2006 - 06:59:45 PM by tactransman »
Terry-tactransman
Union, Mo.
Offline moparclown
Re: Boom ----uh oh
« Reply #11 on: October 11, 2006 - 07:21:14 PM »
When I heard the noise and saw the smoke I shut the ign. off and coasted into the dodge dealership. tonight I removed the drain plug and dumped the rest of the fluid into a clean bucket,and all was clean.I think that I will pull the pan off just to ease my mind.----The Clown
sleepychallenger
Re: Boom ----uh oh
« Reply #12 on: October 11, 2006 - 07:24:53 PM »
if the fluid was clean then i would say leave it sealed and get another converter. i wasnt sure if the fluid was run low for a bit or not or how the fluid looked.
Re: Boom ----uh oh
« Reply #13 on: October 11, 2006 - 10:45:00 PM »
Chryco doesn`t & will never own an auto vehicle
« Last Edit: October 12, 2006 - 02:17:30 AM by Chryco Psycho »
Offline ntstlgl1970
  • T a c o c a t
Re: Boom ----uh oh
« Reply #14 on: October 12, 2006 - 12:31:16 AM »
Is it just me or does the converter/flexplate bolt boss look crooked like the converter is ballooned in the first picture of the converter on the bench (looking and comparing the bolt boss to the converter hub)
