Author Topic: Z-codes ?  (Read 1584 times)
Offline Culvers
Z-codes ?
« on: October 08, 2006 - 09:14:54 AM »
Hello,
what are the Z-codes? Special Equipment Weight, from minus 320 (Z23) to plus 320 (Z37). But what does it means? :clueless:
Culvers
Alaskan_TA
Re: Z-codes ?
« Reply #1 on: October 08, 2006 - 10:58:30 AM »
Those codes were not in use until 1977, but I am not aware of the exact meanings.
Barry
Re: Z-codes ?
« Reply #2 on: October 08, 2006 - 11:56:04 PM »
Or you own a GM trhey all have Z codes ......makes them Special  :smilielol:
Offline Stacked440
Re: Z-codes ?
« Reply #3 on: October 16, 2006 - 09:08:26 PM »
Fifth Digit - Engine
A=170 CID, 6 Cylinder (1 bbl Carb)
B=198 CID, 6 Cylinder (1 bbl Carb)
B=225 CID, 6 Cylinder (1 bbl Carb)
C=225 CID, 6 Cylinder (Special Order)
D=273 CID, 8 Cylinder (2 bbl Carb)
E=225 CID, 6 Cylinder (Special Order)
F=318 CID, 8 Cylinder (2 bbl Carb)
G=318 CID, V8 (2 bbl Carb)
H=340 CID, V8 (4 bbl Carb) HP
H=383 CID, V8 (4 bbl Carb) HP
J=426 CID, V8 (HEMI) (1966 - 1969)
J=340 CID, V8 (3-2 bbl Carb) (1970)
K=440 CID, V8 (4 bbl Carb) (66-69)
K=360 CID, V8 (2 bbl Carb) (70-71)
L=383 CID, V8 (2 bbl Carb) (1970- 71)
L=440 CID, V8 (2 bbl Carb) (67-69)
M=440 CID, V8 (3-2 bbl Carb) (69)
M=440 CID, V* (4 bbl Carb) (69)
M=400 CID, V8 (4 bbl Carb) (71)
N=383 CID, V8 (4 bbl Carb) (1970 - 1971)
R=426 CID, V8 (HEMI) (1970 - 1971)
T=440 CID, V8 (4 bbl Carb)
U=440 CID, V8 (4 bbl Carb) HP
V=440 CID, V8 (3-2 bbl Carb) (1970-1971)HP
Z=Special Order, V8
Special order only available after 77? :dunno:
-Kyle-
Alaskan_TA
Re: Z-codes ?
« Reply #4 on: October 16, 2006 - 09:18:29 PM »
Z is a legitimate engine code, but he was asking about Z23, Z37 and the codes in between.  ;)
Barry
