Author Topic: Checking raditor flow  (Read 717 times)
Offline MusclecarsDK
    • musclecars.dk
« on: October 11, 2006 - 06:56:24 AM »
Is there any way to check if the radiator is clogged inside or not?
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
Re: Checking raditor flow
« Reply #1 on: October 11, 2006 - 07:28:31 AM »
Any good radiator shop can check flow. You will have to remove the radiator and take it in.
If it is clogged up maybe it can be rodded out. My buddy owns a radiator shop and I have seen this done many times.
Worlds first e-body trailer.    Severna Park, Maryland
    • musclecars.dk
« Reply #2 on: October 11, 2006 - 07:30:28 AM »
So there's no way to check it yourself?
Offline purple1
« Reply #3 on: October 11, 2006 - 07:37:55 AM »
You can take it out. Hold your hand over the lower fitting and fill it up with water. Then let go of the lower opening. It should drain in about 5-10 sec. the flow should be almost the size of the opening and strong. if it flows slowly it is cloged and you will have to repair or replace it.
    • musclecars.dk
« Reply #4 on: October 11, 2006 - 07:57:11 AM »
Thanks! I'll try that.
