Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
SE rear window change
« previous
next »
Print
Pages: [
1
Author
Topic: SE rear window change (Read 1134 times)
AMXguy
Sr. Member
on:
October 11, 2006 - 10:02:52 AM »
Can you remove the rear window insert on a Challenger SE and install a standard rear window? would the trim clip studs be a problem also? thanks
Logged
1970 R/T SE Challenger
1970 Superbee
1969 S code Mach 1
1967 GTO
Chryco Psycho
Administrator
C-C.com Guru
Re: SE rear window change
Reply #1 on:
October 11, 2006 - 10:26:44 AM »
yes , the standard rear window will fit with the plug out , aare you eliminating the vinyl roof too ?
Logged
AMXguy
Sr. Member
Reply #2 on:
October 11, 2006 - 10:40:17 AM »
The top and all trim are gone, the small window is all that's left. will the trim clip studs be there?
Logged
1970 Superbee
1969 S code Mach 1
1967 GTO
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
October 11, 2006 - 10:49:01 AM »
Good ?
I believe so , Redline can confirm this for sure though
Logged
Rev-It-Up
Global Moderator
Permanent Resident
Member Since 2/20/02
Reply #4 on:
October 11, 2006 - 01:04:12 PM »
Red's out of town till the weekend. The plug just screws in and I don't recall any studs on the window opening. Here is a pic of ours before we put the window plug back in. I know it's an odd angle...it's looking down from the roof of the car.
Logged
Rev-It-Up Yes, I'm a girl!
AMXguy
Sr. Member
Reply #5 on:
October 11, 2006 - 02:38:17 PM »
OK, so I guess the studs could be put on for the window trim? I don't know if those are welded or what?
Logged
1970 Superbee
1969 S code Mach 1
1967 GTO
PlumCrazy
Jr. Member
Reply #6 on:
October 11, 2006 - 03:11:13 PM »
http://www.cuda-challenger.com/cc/index.php?topic=24988.0
Logged
SilverChally
Sr. Member
Reply #7 on:
October 11, 2006 - 10:34:12 PM »
We have a stud gun to install them, havent used it in years! But it welds them on.
Logged
70 challenger project
68 satellite
Chryco Psycho
Administrator
C-C.com Guru
Reply #8 on:
October 11, 2006 - 10:40:45 PM »
or you can use screws to hold the trim clops in place as long as the trim clips are installed Before the window
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
