72 TB3 Project Challenger for Sale
Author Topic: 72 TB3 Project Challenger for Sale  (Read 1140 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
« on: October 12, 2006 - 08:25:37 PM »
SOLD!!!!!!!!!!!!
FOR SALE:
1972 Dodge Challenger JH 23G2B227013
D34 – TorqueFlite Automatic Transmission
E44 -318-2 Barrel
107056 - Order Number: 107056
B09- Date Built: 11 / 09 / 1971
000- Upper Door Frame: Full Door Panel
B6XW-  Black and white interior, P? trim class
TB3- Blue streak blue – “Petty Blue”
H31 - Rear Window Defogger - Blower
G11 - Tinted Glass All
C56 - Bucket Seats 1972 up
C16 - Console w/ Buckets
U – Built for USA
V1W – white Vinyl top
26 – 26” radiator
V7B - Accent Stripes - Light Blue
R35 - AM / FM Multiplex Stereo
M42 - Front End Molding
M21 - Roof Drip Rail Moldings
H51 - Single Air /w Heater
EN2 - End of Codes Assembly Line 2
Official Relocated Washington state VIN tag. Door matches VIN, rad support and cowl, clear title.
Evaluation:
Relatively solid project car. Please read carefully to understand the extent of this project.
This car had been hit at some point in it’s life. It was rear-ended, and caused the rear frame-rails to kink ever so slightly. I only found this by close examination of the trunk extensions. The only way I noticed it was that the extensions looked like they were warped a bit. I looked carefully across the car to notice a slight  bend in the framerails (under the extensions ) by comparing it to another car. The Framerails are solid, so this could be fixed. You  can not  notice this from the outside. The body line is real straight.
Exterior:
Rolling shell, no valence panels, Tweaked non-rusty bumpers front & rear,
Bumper brackets, no exta fasteners
Body has been reworked with filler- all panels have some filler.
1 exterior door handle missing
Exterior mirror
Glass:
All glass included except for windshield
Window trim molding – side windows trim, some rear and front window trim
Interior:
No interior panels
Interior metal roof trim
Dash frame, ashtray, glovebox door, dash pad core, some plastic dash pieces, no gauge cluster
At least 2 window crank handles
HVAC unit , no rear defogger
Steering wheel,  Mirror
used wiring harness, some relays
Drivetrain:
No drivetrain assembly provided, No transmission, no accessory components.
        Headers and exhaust come with the purchase of this car
Front Fenders:
Both fenders are in decent condition
The passenger fender has some rust on the bolt flange, and needs to be patched.
The drivers fender looks good, but has some filler above the wheel opening
Hood:
The flat hood  has been modified poorly to accept hood pins. The underside had been cut out sloppily, and it will need to be patched, otherwise it is pretty clean.
Doors:
The passenger door has been patched in several areas, but the bottom edge looks good.
The drivers door lower skin needs to be replaced –there is a good amount of filler here.
Pillars/Roof:
Solid, undamaged pillars, seams filled,
The roof is good, no rust or hole
Cowl/Firewall:
The cowl/firewall- the brakebooster area might need a minor patch, the cowl is good
The fender inners – some holes punched, a couple of dents, not rusty by hood hinges.
The cowl windshield F & R minor surface scale form being exposed, not rusted through
Rockers/Sill:
The passenger side rocker looks like it might have been replaced or patched at some point, both real solid
The drivers side looks decent
Rear Quarters/Wheel wells:
Both rear quarters are straight, but could use a partial lower replacement. (Old overlap replacement)
Drivers side rear wheel- well to rocker - looks like it was patched at one time, some bubble coming through the paint
Passenger side wheel well- looks good
Floorpans/Tunnel
Tunnel – Past Owner removed the console attachments that were welded to the floor, needs patching
Drivers Floorpan – needs replacement by footwell, tear by seat frame attachment. Needs patchwork where holes were drilled.
Passenger floorpan – needs partial by footwell
Surface rust from exposure to elements
The underbody looks great. No rust or rot.
The tailpanel is near perfect
Trunk Floor:
The trunk center is extremely solid. No holes or real thin  material. The only area that is somewhat rusty is by the passenger side exhaust hanger
Trunk extensions need to be replaced
Decklid:
The trunklid has some rust on the inside lip
The lid has 4 holes drilled for a spoiler
Here's the link to the complete gallery of EVERY image you could possibly want.
http://www.pbase.com/dmz73/72_challenger
Best Offer!
This vehicle is being sold for parts only and is not operational or street legal. Therefore, upon purchase, it will need to be either towed or trailered.Please learn aboutstate laws governing vehicle sales prior to the sale or purchase of a vehicle.”
Offers welcome. This car is located in BLoomfield Twp. Michigan, Zip 48304
This is super solid, not a rustbucket. This would make a great car. Pleas ebring it back to life!
E-mail me for more  info:
DZimmermann1@aol.com
Thanks,
Dan Zimmermann
« Last Edit: October 22, 2006 - 03:52:15 PM by DMZ73 »
Offline dukeboy_318
Re: 72 TB3 Project Challenger for Sale
« Reply #1 on: October 16, 2006 - 05:07:15 PM »
 :useless:
Offline Cuda Cody
  • Vancouver, WA
Offline DMZ73
« Reply #3 on: October 16, 2006 - 08:08:04 PM »
Thanks Cody. My preview shows that the link I put in the post is working, but who knows...
ANyway, They car MUST GO!
I have 2 kids too many bills and a car that I am not doing anything with. Who knows where it will go. The car is really solid. Someone would be happy.
Here's the link to the auction:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=020&item=300038758197&rd=1&sspagename=STRK%3AMESE%3AIT&rd=1<
Dan
