cudaaah
With all those lamps not working I can't imagine you have that many burned out bulbs.
*Keep in mind that I'm using 1970 'Cuda schematics but I think they're all the same*
I know you said you checked the fuse but sometimes it could "look" good and the filament is actually broken. There's a 3 amp fuse labelled "Inst" (top right of the fuse box) that supplies power to: radio lamp, heater control lamp, gauge lamps(4), ashtray lamp, console shifter lamp & steering column lamp (if you have them). Power to that "instrument lamp connector" (that I mentioned earlier) is actually tapped off from the radio lamp plug. Anyway, you need to check for 12volts on both sides of the 3 amp "Inst" fuse. Also, check for rust and/or corrotion there. Keep in touch.
John
