Author Topic: Which yoke/uni combo? 8 3/4 conversion on 318 - 7 1/4 Barracuda.  (Read 1649 times)
Offline OzCuda
« on: October 15, 2006 - 05:15:30 AM »
Need some help guys so that I get the right parts.  Putting an 8 3/4 diff into the Barracuda to replace the 7 1/4.  Have 29 spline 3.55 ring and pinion already and was going to order the yoke to suit but not sure what size uni joint was used on my 318 driveshaft?  Were there differences?  There seems to be multiple yokes available and ultimately I need to order the one that suits my original driveshaft.
Also wondering if the original driveshaft that came off the 904 auto trans will work with the 727 trans I am fitting??  If the drivesahft doesn't isn't compatible then the rear yoke becomes a side issue?????
« Last Edit: October 15, 2006 - 05:24:51 AM by OzCuda »
'70 Barracuda
Offline tactransman
Re: Which yoke/uni combo? 8 3/4 conversion on 318 - 7 1/4 Barracuda.
« Reply #1 on: October 15, 2006 - 06:44:56 AM »
Rearend Yoke ID Info  2 1/8" = 7260   2 5/8" = 7290
Driveshaft will need a 727 yoke installed on the front u-joint and shortened around 3 3/4 to 4 inches. :thumbsup:
« Last Edit: October 15, 2006 - 06:51:09 AM by tactransman »
Terry-tactransman
Union, Mo.
Alaskan_TA
« Reply #2 on: October 15, 2006 - 10:08:46 PM »
There is also a conversion U-joint available that can mate a large yoke to a small one. From memory I believe the NAPA part number is 347 ?
Barry
Offline tactransman
« Reply #3 on: October 16, 2006 - 06:44:00 AM »
7260-7290 conversion U joint. Big to Small U Joint :thumbsup:
TRW part # 20226.
Mancini ........... 5-527X
Auto Zone ........... 2-0527
NAPA ............... NUJ240-0369
Neapco ............. 2-0527
Terry-tactransman
Union, Mo.
Offline OzCuda
« Reply #4 on: October 16, 2006 - 11:11:18 PM »
Thanks guys but I am a bit confused by the conversion U-joint option.  Working on the assumption that I have the small yoke on my driveshaft (measure that tonight), then my first option is get get the matching pinion yoke and get the matching uni joint.  As I understand it, I can order the larger pinion yoke and use the listed uni joint to adapt it to my driveshaft.  I'm guessing the only reason to go down this path is if they send me the wrong yoke so at least I have options, or if I am planning on upgrading the driveshaft later?
Will the smaller uni joint be sufficient for a mildly worked 383 driveline???
Also, if I have to modify the driveshaft anyway to shorten and fit 727  slip yoke, I suppose I should go the bigger joint anyway??
« Last Edit: October 16, 2006 - 11:14:23 PM by OzCuda »
'70 Barracuda
Offline tactransman
« Reply #5 on: October 17, 2006 - 06:35:14 AM »
I'm guessing the only reason to go down this path is if they send me the wrong yoke so at least I have options, or if I am planning on upgrading the driveshaft later? YES
Will the smaller uni joint be sufficient for a mildly worked 383 driveline??? YES
Also, if I have to modify the driveshaft anyway to shorten and fit 727  slip yoke, I suppose I should go the bigger joint anyway?? If you might go to more horsepower later
Terry-tactransman
Union, Mo.
Alaskan_TA
« Reply #6 on: October 17, 2006 - 03:16:24 PM »
Tact,
Did Napa change numbers? I have had this one in my tool box as a spare for years;
Offline tactransman
« Reply #7 on: October 17, 2006 - 03:24:19 PM »
 :dunno: That info is from Moparts tech archives. http://www.moparts.com/Tech/Archive/shaft/4.html
Terry-tactransman
Union, Mo.
Alaskan_TA
« Reply #8 on: October 17, 2006 - 04:39:27 PM »
OK, I called my brother (he works for NAPA) the 347 number has been superceeded by the NUJ240-0369 number.  :thumbsup:
Barry
Offline OzCuda
« Reply #9 on: October 17, 2006 - 05:27:03 PM »
Thanks guys, I measured up last night and I do have the smaller unis as expected.  One final question (I get my moneys worth out of you guys don't I), can you confirm that I am able to buy a 727 slip yoke that will take the 7260 uni?
Doh, I can use the adaptor uni if needed :screwy:
« Last Edit: October 17, 2006 - 05:30:02 PM by OzCuda »
'70 Barracuda
Offline tactransman
« Reply #10 on: October 17, 2006 - 05:38:47 PM »
That is going to be the most common one to find in the salvage yards. :thumbsup:
Terry-tactransman
Union, Mo.
