Author Topic: 4 SPEED transmission  (Read 8273 times)
Offline CUDABRUCE
« on: October 15, 2006 - 07:29:21 PM »
I have bought some parts at a estate sale and it was a 4speed trans could someone tell me how i identify this trans it has a part number on the shifter side and the front of c13546 then 11b11883 could someone tell me what i have it was attached to a 340 engine i just wondrign would it be a a-833 trans i,m not a chrysler expert thanks.
« Last Edit: October 18, 2006 - 11:54:38 AM by CUDABRUCE »
Alaskan_TA
Re: 4 SPEED TRNASMISSION
« Reply #1 on: October 15, 2006 - 07:33:24 PM »
The casting numbers will not tell you anything.
Does it have one shifter mounting pad or two?
Is 11b11883 from the VIN pad? If so can you double check it?
What is the stamped number right below that one if it is on the VIN pad?
Barry
Offline CUDABRUCE
« Reply #2 on: October 16, 2006 - 06:03:39 AM »
Barry
But does the 883 on the last digits mean that it's a -833 trans thanks
Alaskan_TA
Re: 4 SPEED transmission
« Reply #3 on: October 16, 2006 - 10:54:15 AM »
If that number is on the VIN pad, then no, it would mean that the VIN of the car it came out of ended in 883. Can you double check the number? If it IS a VIN two of the numbers are out of order.
There is a series of tiny numbers stamped into the VIN pad as well, list those, answer the other questions I asked and we can tell you a lot more about it.  :bigsmile:
T/Ake care,
Barry
Offline CUDABRUCE
« Reply #4 on: October 18, 2006 - 10:11:52 AM »
I have bought some part at a estate sale and 1 was a 4speed trans could someone tell me how i identify this trnas it has a part number on the shifter side and the front of c13546 then 11b11883 could someone tell me what i have thanks.
The only nubers i see that could be a part number are c-1356 then  b cast after that ,the tail shaft housing numbers are c99539 and yes it has two different shifter mounts thanks.
Offline CUDABRUCE
« Reply #5 on: October 18, 2006 - 12:30:03 PM »
Can anyone help on this please.
Offline PlumCrazy
« Reply #6 on: October 18, 2006 - 12:40:49 PM »
So, you have no numbers at all on the pad?  Where is the 11b11883 at?
Alaskan_TA
« Reply #7 on: October 18, 2006 - 01:45:18 PM »
If you can post a photo of the pad on your trans like shown in the photo above it will help us help you.  ;)
Barry
Offline CUDABRUCE
« Reply #8 on: October 18, 2006 - 04:18:51 PM »
Barry
on the pad the only number legible is a p83 then a 219 number the other numbers i have posted were cast into the transmission at the very front l/side it,s c-13546 then a 11b1883 but they are cast in the trans on the shifter side at the front.thanks
Alaskan_TA
« Reply #9 on: October 18, 2006 - 07:14:26 PM »
Then about all we can tell you is based on the two shifter pad mounts. With those, it came from either a B or E body.
Barry
Offline CUDABRUCE
« Reply #10 on: October 19, 2006 - 10:23:07 AM »
Barry
So what i.m asking is it a 883 transmission thats what i,m trying to find out it does have the chrysler star on it. thanks for anyones help.
« Last Edit: October 19, 2006 - 02:37:27 PM by CUDABRUCE »
Offline CUDABRUCE
« Reply #11 on: October 22, 2006 - 09:32:55 AM »
Can anyone tell me if the transmission i have is a 833 trans by what i've described so far please
Offline 4Cruizn
  • HEMI FISH
« Reply #12 on: October 22, 2006 - 11:40:45 AM »
Post a pic and you will have an accurate answer faster!   :picture:   :thumbsup:
Offline moparnut
    • My Photo's
« Reply #13 on: October 23, 2006 - 08:51:23 AM »
The car that came out of was a 69 plymouth belvedere or sattelite with a 383hp.I would assume its a B body 4 speed.
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline CUDABRUCE
« Reply #14 on: November 05, 2006 - 02:35:37 PM »
heres some pictures can someone tell me what kind of trans is this thanks.it has 2 shifter mounting points
