Author Topic: Challenger Doors.  (Read 2816 times)
Offline Challenger6pak
Challenger Doors.
« on: October 16, 2006 - 01:35:54 PM »
Are there any differences between a 1971 Challenger door and a 1974 Challenger door?  Thanks.
« Last Edit: October 16, 2006 - 01:40:10 PM by Challenger6pak »
Re: Challenger Doors.
« Reply #1 on: October 16, 2006 - 01:41:15 PM »
yes , the wil phisically fit Bit there are a few minor differences in the hardware used & the side beam is heavier in the later doors
« Reply #2 on: October 16, 2006 - 01:45:42 PM »
What are the differences.  I have a 71 door (original to my car) that needs rust repair.  I also have a rust free 74 door.  I am trying to decide if the differences are enough to merit fixing the 71 door.  Thanks for your help Chryco.
« Reply #3 on: October 16, 2006 - 03:27:45 PM »
I'm sorry I can't be of more help, but I just recall some difference in the weather stripping of the door panels. The 70-71's had them slipped on, while the later years had them screwed on. I see no reason for you not to use the later year door. That was the only difference I noticed.  :dunno:
Offline Wang
  • "just hangin' out"
    • valleyautoworks.net
« Reply #4 on: October 18, 2006 - 04:41:51 PM »
IMHO, just use the clean door , who can tell once they are installed on the car and reassembled? (save money to boot)
Hurry,, Duane the tub,,I'm Dwouning....
« Reply #5 on: October 20, 2006 - 11:39:45 PM »
I know there are some slight differences if only in the weight of the side beam etc , I believe some of the window hardware changed slightly , I was hoping someone else would jump in with some specifics as well
Offline bb71challenger
« Reply #6 on: October 20, 2006 - 11:48:06 PM »
I had a 73 door that I got a tinted window out of for my 71 and there are definitely differences in the glass hardware. The glass fuzzies are different and bolt up to different points if I remember right. I did not know the beam was heavier but I do know that it is one heavy sob to throw on your shoulder and carry  :eek4: I ended up trading it for a 70 door. I would not think the differences would be enough to go with a rotted out one but since my original door only has a small rust spot where the drain hole was plugged with sand I am going to repare it anyway.
*Brett*
Offline 1 Wild R/T
« Reply #7 on: October 20, 2006 - 11:54:19 PM »
The 70 door is the odd ball 71-74 the shell is basically the same, 71 started the screwed on weatherstrips (window fuzzies) the glass changed in 72, the regulator & guides also changed in 72, 71 & up has the door latch that allows you to lock the door from the inside while the door is open, can't do that on a 70...Use the 73 door but use all the parts from the 71 door.. :2cents:
Offline SilverChally
« Reply #8 on: October 21, 2006 - 11:04:07 PM »
I took some doors off a 74 cuda, those suckers were HEAVY!!!  Guess I know why now :thumbsup:
70 challenger project
68 satellite
« Reply #9 on: October 22, 2006 - 06:09:23 AM »
Thanks for the information.  I didn't realize there were so many differences.  I am going to have to lay them out side by side and decide what to do. I have to use the 71 glass due to the fact it is for my convertible.  It might be easier to fix the 71 door so I know everything will fit.
