Author Topic: Where do I stick my probe?  (Read 2236 times)
Offline torredcuda
  • Epping NH joined 11/23/03
« on: October 16, 2006 - 04:32:49 PM »
...my temp gage probe that is! I am switching to an aftermarket temp gage after overheating at the track friday night when the factory gage was reading right in the middle.I figure the gage is off or was stuck but the problem is the probe for the aftermarket gage is too large in diameter and too long to fit the bung where the stock one was.Where do you guys mount yours?Do I need some typr of adapter for the intake or is there somewhere else to mount it?
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Re: Where do I stick my probe?
« Reply #1 on: October 16, 2006 - 04:39:18 PM »
I'm sorry I can't answer your question, but have you thought about replacing the original temp. sending unit? They are pretty cheap, and that might be all you need.  :dunno:
« Reply #2 on: October 16, 2006 - 04:49:35 PM »
big blocks have a plug in the top of the housing near the heater hose tubes
 small block would need to be tapped into the intake manifold
Offline torredcuda
« Reply #3 on: October 16, 2006 - 04:49:57 PM »
I figure I already have the Autogage unit lying around and once I verify it is accurate by using a meat thermometer I will have a nice gage with actual temp increment readings which the stock one doesn`t have.
Jeff
Offline torredcuda
« Reply #4 on: October 16, 2006 - 04:52:31 PM »
It`s a small block.So where is the best place to tap it,right thru the original hole or somewhere else.The intake is coming off anyway to fix a minor gasket leak so it will be no problem to drill it anywhere.
Jeff
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #5 on: October 17, 2006 - 12:38:44 AM »
I'm assuming that you're using a mechanical gauge.  I had the same dilemma!  :banghead:
I used an electric temp gauge and used the factory sending unit.
Offline Mopar73340
« Reply #6 on: October 17, 2006 - 01:41:47 PM »
I tapped a second hole right next to the factory sending unit.
Offline Got JOB
  • Member since 2-14-06
« Reply #7 on: October 17, 2006 - 03:58:01 PM »
I had a bung placed in the top tank of the radiator .
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline matt63
« Reply #8 on: October 17, 2006 - 06:01:25 PM »
I used the electric unit instead of the mechanical oneto fix that problem.  Otherwise it requires drilling and tapping of the intake.  The drill bits were $50!
Matt in Edmonton
'68 Valiant
Offline CUDA JAS
  • vroooooom!
« Reply #9 on: October 19, 2006 - 03:02:24 PM »
I have a mechanical gauge in my 360 and did not have to drill the intake (aftermarket).
I used and adapter to enlarge the smaller hole.
I can take pics tonight if you would like?
Jas
74 'cuda 360/727
Just call me a gearhead!
Offline GoodysGotaCuda
« Reply #10 on: October 19, 2006 - 03:17:55 PM »
I just got a few brass fittings at lowes and plumbed my mech temp gauge in my dusters heater lines...
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #11 on: October 19, 2006 - 08:20:04 PM »
Jas
 :clueless: Very curious to see what this looks like if you don't mind.
Is the sensor above the level of the manifold then?  :dunno:
Offline CUDA JAS
  • vroooooom!
« Reply #12 on: October 20, 2006 - 06:09:14 AM »
I did not get a chance to take a pic last night.
Here are a couple of that I have on my computer.
You can see the sendign unit in the from pass side corner of the intake.  It is the one with the think black line coming from it.
Yes it sticks out of the intake abit, but it works.
Let me know if you want some up close shots.
Jas
74 'cuda 360/727
Offline torredcuda
« Reply #13 on: October 20, 2006 - 07:27:26 AM »
I ended up drilling out the factory hole to a larger size as the sensor would not fit into the stock hole and making up an adpater to mount it.It turned out good so I`ll get some pics this weekend.
Jeff
« Reply #14 on: October 20, 2006 - 08:33:38 AM »
 :thumbsup: Thanks for the pic CUDA JAS!
I might check that out as some times I get some feedback from the alternator or something and the temp goes up when the RPMs go up!
