Author Topic: 833 transmission ID question.  (Read 2457 times)
Offline Pistol Gripper
« on: August 03, 2003 - 08:27:52 PM »
Hi all,
I have 2 4 speeds that I'm trying to find out a bit more info on.  They are both long tailshaft models with two shifter mounting flanges ( B & E ).  On one the holes for the E-body aren't drilled and tapped, the other is.  Both have the number C-13546 on the case.  The IBR ( input bearing retainer ) is 5.125"  leading me to believe these are 833 OD trannys.  Did they come with long tailshafts or did someone already convert these ?
Thanks,
P.G.
O ne
B ig
A $$
M istake
A merica
Re:833 transmission ID question.
« Reply #1 on: August 04, 2003 - 02:57:52 AM »
the onlt 833 to use the 5.125 brg retainer was the OD , the front shift lever will point down instead of up too .
 The long shaft OD was available in trucks & vans until 93
« Reply #2 on: August 04, 2003 - 04:54:26 AM »
Thanks Chryco,
Only one had the shift levers on it, one did point down ( not sure which one ).  Also the 3rd. gear looks pretty small.  Now to find the time to rebuild one  ;D
P.G.
O ne
B ig
A $$
M istake
A merica
Offline cuda
  • 1970 340 Cuda, pistol grip 4 speed,3:91 sure grip
« Reply #3 on: August 04, 2003 - 07:45:37 AM »
I love my 833 O.D. its the best of both worlds, bottom and top end!!!
