Author Topic: 70 to 71 Cuda front clip conversion - how painful?  (Read 711 times)
Offline JeffAARy
  • Orange Mopars Drive Me Wild
« on: October 19, 2006 - 12:46:01 AM »
I'm thinking of putting a 71 front clip on my 70.  How painful is this?  I'm seeing/anticipating the following:
1)  Different header panel
2)  Turn signal harnesses needs to be lengthened?
3)  What has to be done to go from 2 headlights to four?
Also, how hard is it to change the headlight buckets if I turn 70 fenders into 71?  Are these welded on or bolted on?  I haven't taken a close look.
-Jeff
Re: 70 to 71 Cuda front clip conversion - how painful?
« Reply #1 on: October 19, 2006 - 01:31:16 AM »
the headlight buckets need to be changed & THE gills added , the buckets are spot welded , you will need a different front valence
Offline willhaven
« Reply #2 on: October 19, 2006 - 05:30:56 PM »
Do they repro the '71 front valance panel yet?
« Reply #3 on: October 19, 2006 - 05:55:35 PM »
lower yes, upper don't think so yet.
