Author Topic: How do I change the Shift Indicator Light ?  (Read 2467 times)
Offline Madmax440
« on: October 19, 2006 - 11:53:49 AM »
The light in the console that lights up my the shift indicators must have burned out. What is the easiest way of changing this other than using a flashlight now ???
Offline GoodysGotaCuda
Re: How do I change the Shift Indicator Light ?
« Reply #1 on: October 19, 2006 - 12:51:02 PM »
Should be able to just remove the top plate and get to it there.  :clueless:
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #2 on: October 19, 2006 - 03:00:52 PM »
It's been a while, but I think you have to take the console out. It(the light) just fits up underneath the shifter. It's a cheap cheesy socket on the end of an orange wire, so be careful. The socket also needs to make good contact as that's were it gets it's ground connection.
« Last Edit: October 19, 2006 - 03:53:43 PM by MEKrunner »
Offline Street_Challenged73
« Reply #3 on: October 19, 2006 - 03:32:47 PM »
I'm pretty sure you have to do what MEKrunner suggested.  It should be up underneath the shifter assembly as he said. :thumbsup:  It may be possible to get to with just the top plate off, but that may be too small of an area to get access to the light bulb.
Offline JayBee
« Reply #4 on: October 19, 2006 - 04:29:57 PM »
Just looked at my car in the garage 'cause the console's in the basement and - yep, I don't see any other way to get to it other than removing the console itself. Oh, and it does plug in underneath the shifter.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Madmax440
« Reply #5 on: October 19, 2006 - 05:55:11 PM »
Wow - This sounds like major operation just to change a light bulb. Thanks, Guys.
« Reply #6 on: October 19, 2006 - 06:38:23 PM »
Actually it's not.  :lol:
 The big trouble I had was aligning the console to screw it back in place.  :pullinghair:
Offline Madmax440
« Reply #7 on: October 19, 2006 - 08:42:56 PM »
Thanks - All done. After removing the cover plate and T handle, I was able to remove the three bolts that holds the shifter plate down. Removed the one in the back and then put it in 1st gear and removed the front two. At that point the shifter plate lifted right out and simply changed the bulb and put it all back together - 15 minute job. I had forgotten that the indicator shows a different color as it goes through the gears. Like wow man - Cool.
Offline 71bigblock
    • Steve's Mopars
« Reply #8 on: October 20, 2006 - 04:29:39 PM »
I just replaced mine too, it was like, bam, color!   :wow: I didnt remove the console, just the plate and the three screws also.
Offline droptop340
  • Newbie
« Reply #9 on: July 31, 2022 - 03:01:05 PM »
Anyone tell me where the wire plugs in under the dash I am having a hard time figuring it out. Thanks in advance
Offline JayBee
« Reply #10 on: August 01, 2022 - 08:42:35 AM »
The orange bulb wire plugs in behind the right side kick panel. That harness goes to a triple orange plug above the radio area.
Look at my Reply#9 in the following link...
https://forum.e-bodies.org/interior/6/wiring-questions/1402/
« Last Edit: August 01, 2022 - 09:00:58 AM by JayBee »
John
2014 Toyota Avalon
