Author Topic: Work has begun...Topcat  (Read 260408 times)
Offline twalker
Re: Work has begun...Topcat
« Reply #885 on: October 13, 2014 - 11:52:54 PM »
Wow, sounding good
Offline CudamanTom
« Reply #886 on: October 14, 2014 - 06:48:52 AM »
Love it!!!  :ylsuper: :clapping: :2thumbs:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline swe_challenger
« Reply #887 on: October 14, 2014 - 05:43:25 PM »
Sounds great, love it!! :wow:
Stefan Alvsbyn Sweden
Offline daaboots
« Reply #888 on: October 16, 2014 - 01:09:19 PM »
Just making the videos inline  :thumbsup:
Waking up a Mamoth from her sleep.
She won't wake up from hibernation and run fast until she gets her feet going. I need to help.
Once the jets/metering rods are upgraded and the cam hot lash set; I bet she's going to be running alot better.
1st attempt.
www.youtube.com/watch?v=n-dZC6s__lw
Finding what does she want?
www.youtube.com/watch?v=zNY7JFAI7ck&feature=youtu.be
Getting better
www.youtube.com/watch?v=RKSfLBey6r8&feature=youtu.be
This is the break in,
She was running lean as we learned. Later on it was discovered that one of the mechanical advance springs were disco'd. No wonder getting it timed was impossible.
https://www.youtube.com/watch?v=qY-NrZt66bk&feature=youtu.be
Offline willhaven
« Reply #889 on: November 14, 2014 - 06:23:13 PM »
I've really enjoyed this build. Very happy for you!  :thumbsup:
« Reply #890 on: November 16, 2014 - 06:31:55 PM »
Thank you!
I spent all day restoring pictures on my thread here.
Now you can go back and see alot that were missing or Red X'd.
Still more to do.
Offline ToxicWolf
« Reply #891 on: November 17, 2014 - 11:44:07 AM »
They are never finished, TC.   :roflsmiley:
Offline Plum6Pak
  • Plum6Pak
« Reply #892 on: January 05, 2015 - 12:20:02 PM »
Thank you!
Still more to do.
Wow! I went back and looked through this, it's amazing where you began and where you ended up!!! Nice thread to understand just what we go through to get some of these where they are at today! Nice!!!
Offline JoeGrapes
« Reply #893 on: January 07, 2015 - 03:16:29 PM »
Wow Topcat, absolutely beautiful car! Great job.
« Reply #894 on: January 07, 2015 - 10:06:16 PM »
thanks,
It's really never finished.
Starting to buy shaker parts now. Little by Little.
Still need to change the schumacher mounting brackets to lower it 1 inch for bubble clearance.
Offline Sleepychallenger
« Reply #895 on: January 20, 2015 - 09:31:17 AM »
Was there a template you used to cut the hood?
« Reply #896 on: January 20, 2015 - 09:40:37 AM »
No template.
17 1/4" hole drilled from back after under side is felt marked/scribed.
« Reply #897 on: January 21, 2015 - 10:06:57 PM »
I see. I have a flat hood I'm thinking about cutting but not sure
« Reply #898 on: January 21, 2015 - 10:14:34 PM »
Just buy one made.   :2cents:
It was a ton of work and when I was halfway thru, I wished I had.
« Reply #899 on: January 21, 2015 - 10:32:58 PM »
Looking good :2thumbs:  Sounds like a few loose valves maybe. It will hold better idle and vacuum once you reset them.  If that was your first run, congrats to you.  Hard to adjust it all during intial break in.   love it
