Author Topic: 340 or 440  (Read 3205 times)
Offline 71chmark
340 or 440
« on: October 22, 2006 - 06:30:55 PM »
What would be the advantage of a 340 over a 440?
I may be schizophrenic,
Re: 340 or 440
« Reply #1 on: October 22, 2006 - 06:52:12 PM »
weight
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: 340 or 440
« Reply #2 on: October 22, 2006 - 08:32:27 PM »
weight
:iagree: and maybe fuel mileage.
The price would be close to the same, just depends on you are looking for power wise.
Offline oldkimmer
Re: 340 or 440
« Reply #3 on: November 02, 2006 - 07:43:09 PM »
handling
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Offline Carlwalski
Re: 340 or 440
« Reply #4 on: November 02, 2006 - 07:50:45 PM »
100lbs difference rule of thumb, costs about 10hp, so, bugger all really.
Handling of course is improved, I guess it depends on the application.  :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline moper
Re: 340 or 440
« Reply #5 on: November 03, 2006 - 07:53:22 AM »
Using it for what? :clueless:
Offline mrbill426
    • All Around Mopars
Re: 340 or 440
« Reply #6 on: November 03, 2006 - 11:16:13 AM »
handling
Are the 440 cars really bad on handling?
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Re: 340 or 440
« Reply #7 on: November 03, 2006 - 12:30:04 PM »
not in my experience , larger T bars & sway bars seem to compensate well
Offline 71fish
  • Bless you..
    • Ken's 71fish
Re: 340 or 440
« Reply #8 on: November 03, 2006 - 12:51:35 PM »
building a stroker 340 ~ $4200..
building a 440 ~ $4700..
..SMOKING a BB with a 340.. PRICELESS    :bigsmile:
-71fish
71fish - Nobody better than an E-BODY!!
Offline mrbill426
    • All Around Mopars
Re: 340 or 440
« Reply #9 on: November 03, 2006 - 01:07:35 PM »
-71fish
Well, okay, but what are the resulting cubic inches of stroking that 340?
 :working:
MOPAR or NO car!
Offline 71fish
  • Bless you..
    • Ken's 71fish
Re: 340 or 440
« Reply #10 on: November 03, 2006 - 01:09:50 PM »
408 or sumthin..
Offline matt63
Re: 340 or 440
« Reply #11 on: November 03, 2006 - 01:53:44 PM »
A stroke 340 is about 416 CI.  I think the answer to your question depends on your hp requirements.  I just finished a 408 (stroked 360).  It's got a ton of torque.  I would say that the small blocks are great for up to about 450hp. Blocks are more readily available (360).  After that the cylinder wall thickness and head bolting/head gaskets are the weak links.  Perhaps an R3 block would be the way to go but you would have to double the budget.
Matt in Edmonton
'68 Valiant
Offline Oldschool
  • Member Since 9-05-06
Re: 340 or 440
« Reply #12 on: November 03, 2006 - 05:41:58 PM »
440 with aluminum heads and lightweight components wouldn't be much heavier than a 340 and the performance potential is much higher....    :cooldancing:
Ken  --  In Georgia
Offline EVIL72
Re: 340 or 440
« Reply #13 on: November 03, 2006 - 11:31:13 PM »
 How about dropping another 50lb's or so off the 440's weight by using a 400 block instead and stroking it to a 451, 470 or 500ci  :ylsuper:
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline 1973challenger360
Re: 340 or 440
« Reply #14 on: November 04, 2006 - 08:39:26 PM »
i HAVE NEVER HEARD OF A B MOTOR BEING 50LBS LIGHTER THAN AN RB AND IF IT IS IT MIGHT BE BECAUSE OF LESS STROKE AND THE CRANK BEING LIGHTER SO IF U PUT A 440 CRANK IN A 400 YOU HAVE WHAT ?? A B THAT WEIGHTS THE SAME AS AN RB MINUES A LITTLE BIT OF WEIGHT FROM A HEIGHER DECK.
tHE RULE IS 100LBS 1/10 SECOND
DOUBLE HE WEIGHT QUADDRUPEL THE HP
