Author Topic: Performance Motors Overheating at Idle  (Read 2476 times)
Offline zerfetzen
  • 'Cuda, should'a, would'a...you lost.
« on: October 23, 2006 - 11:13:28 AM »
What causes performance motors to overheat at prolonged idle?  If you want to build a powerful street motor, how do you avoid this?  Thanks.
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Performance Motors Overheating at Idle
« Reply #1 on: October 23, 2006 - 12:19:17 PM »
 :popcorn: I'm curious too!
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #2 on: October 23, 2006 - 12:47:50 PM »
I know a few of the reasons could cause over heating:
-high compression
-cylinder walls have been over-bored too much
-timing is advanced to far at idle
-lack of a thermostat will not let the water have time to cool in the radiator
-need a shroud around fan
-restricted water flow due to corrosion
-clutch fan not working correctly
I am sure there are many other reasons, but is all I can think of real quick.
« Reply #3 on: October 23, 2006 - 02:49:20 PM »
Corrosion in the radiator is always my first thought. Also, all these hi-powered enigines have headers. Sitting in traffic can turn the engine bay into an oven if there is no airflow to cool it.
Offline Jacksboys
« Reply #4 on: October 24, 2006 - 12:45:37 AM »
« Reply #5 on: October 24, 2006 - 12:59:20 AM »
volume of water is critical ,hAVING A LARGE ENOUGH & & clean rad is Key ,also air flow ,7 blade clutch fans with a shroud will beat virtually any other system , the other key is getting air out of the engine compartment , it is one thing to pull enough air with the fan but there must be somewhere for the air to go out from the engine compartment as well or the efficiency of the fan is compromised
 My 11 second duster ran extrmely coolin traffic etc But it had fender headers & the inner fenders were entirely removed from the car , i never had this car run hot even making 14 back to back passes down the race track at full throttle without ever turning the car off between runs
Offline zerfetzen
« Reply #6 on: October 24, 2006 - 05:59:21 AM »
Thanks guys
Offline Dragula
« Reply #7 on: October 29, 2006 - 12:09:04 PM »
Never had the problem at idle, but at cruising speed is another story. If your at an idle, and it gets hot, your cooling system isn't flowing enough air, and your water pump might not be helping as much as it should at low speeds.
Ever go to the car shows and see/hear a performance engine and look under the hood only to see that they upgraded the engine with headers, a new cam, heads, and intake, but stuck it back into a stock engine bay with the stock radiator, fans, and damper. At certain levels, it requires other things to be upgraded as well. The stock water pump with throw fit tolerances thats now 35+ years old isn't going to flow well enough to really keep up, nor was the stock rad that they had re-cored able to keep up. You need to address the areas that support the upgrades. Even if you want it to look stock, a brand new pump and radiator will out perform the old units by a bunch just by the newer manufacturing tolerances.
Would you run a points ignition on your $5k rebuilt 440, or would at least bring it up it to the basic chrysler orange box kit? When you get to the next level, you need to upgrade again, or performance issues show their ugly head in weird ways. As the saying goes, all the parts gotta match. :blah:
« Last Edit: October 29, 2006 - 12:13:08 PM by dragula »
