Author Topic: !!! need Help soon (again) Brake line part ???  (Read 1699 times)
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« on: October 25, 2006 - 04:21:47 PM »
Can anyone tell me the correct name (and where I can get one) of the front brake part that is bolted to the same bracket that holds the "brakehold off valve" and the "warning sensor valve".
The part I need has a "button" switch and brake lines to it. My car is a '70 Challenger with front power discs. It is leaking and it's currently in a shop.
They're not sure what it is/does either. HELP !!
 :feedback:
Thanks !!
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Re: !!! need Help soon (again) Brake line part ???
« Reply #1 on: October 25, 2006 - 11:57:43 PM »
proportioning valve , not available except Ebay , it can be rebuilt though
Offline PlumCrazy
« Reply #2 on: October 26, 2006 - 01:50:44 PM »
 :feedback:
Thanks !!
Depending upon when your car was built, you would have the metering valve and a safety switch with the prop valve farther down on the frame rail or the metering valve and a combo safety switch/prop valve.
Offline Lunchbox
« Reply #3 on: October 27, 2006 - 10:43:23 PM »
Is this the part you are talking about? If so who rebuilds them??
« Reply #4 on: October 28, 2006 - 05:20:13 AM »
These guys list a replacement Proportioning Valve
http://www.mbmbrakeboosters.com/mopar.html
this article shows the inards of the swith, looks like a couple of o-rings would fix leak, probably the same for prop. valve.  :dunno:
http://www.imperialclub.com/Repair/Lit/Master/232/Page07.htm
« Last Edit: October 28, 2006 - 05:49:08 AM by bullitt99 »
  • HvacMan
« Reply #5 on: October 28, 2006 - 09:09:47 AM »
decided to replace the whole combination set-up with a modern replacement.
Has anyone done this update on their car?
Eric
Bay Area California
Offline ShelbyDogg
« Reply #6 on: October 30, 2006 - 11:22:26 AM »
I have a '70 with the '72 model proportioning valve on it.  It works fine.
