Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Motor mount brackets
« previous
next »
Print
Pages: [
1
Author
Topic: Motor mount brackets (Read 814 times)
mrbill426
Full Member
on:
October 26, 2006 - 10:11:58 AM »
As I understand it, in order to swap in a big block where a small block once was you must use big block mounting brackets. Does it matter what body the brackets came out of? I'd be swapping in a 440 from a '66 Imperial and do have the brackets from that car. Or, do I NEED brackets for a big block E-body?
Logged
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Chryco Psycho
Administrator
C-C.com Guru
Re: Motor mount brackets
Reply #1 on:
October 26, 2006 - 10:16:14 AM »
not sure about the 66 Imperial brackets , I believe they will work though , virtually any mount from 66-72 was the same for the big blocks
Logged
mrbill426
Full Member
Reply #2 on:
October 26, 2006 - 10:54:41 AM »
Excellent, thanks Chryco
Bill
Logged
MOPAR or NO car!
MOPAR FANATIC
Resident
Reply #3 on:
October 26, 2006 - 12:46:25 PM »
Don't you have to change the k-frame if your not using aftermarket mounts from a smally to a big block?
Logged
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
mrbill426
Full Member
Reply #4 on:
October 26, 2006 - 01:01:02 PM »
I think the K frames are the same, just the brackets are different.
Logged
MOPAR or NO car!
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
October 27, 2006 - 12:20:53 AM »
all V 8 K frames are the same with the exception of the hemi , the HP had a skid plate welded to the bottom of the K frame to protect the oil pan originally
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
