Author Topic: skim coat over primer  (Read 1500 times)
Offline chall7074
« on: October 26, 2006 - 09:26:08 PM »
new to sight, I need a little help. I am only able to work on my car on weekends. I need to seal metal work with primer I need to know do I have to remove all the primer before I skim coat or can I rough it up and apply filler to primed surface. I have been told yes and no. I would really appreciate any help and comments
Offline inot2old
Re: skim coat over primer
« Reply #1 on: October 27, 2006 - 04:27:37 PM »
I'm sorry I can't help you with your question, I am sure someone here can.
I just want to welcome you to the site.  You should go to the new member section and introduce yourself. :wave:
'71 Cuda
'70 Charger project
'05 Crossfire Roadster
Offline EvilTwinATX
« Reply #2 on: October 27, 2006 - 05:28:51 PM »
in short... yes you can. PPG actually recommends that you do it this way, but you should rough up the area with 80 grit first....
Unless of course you are using fiberglass, then you should go down to bare metal with something rough to give the glass something to "bite" into.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #3 on: October 27, 2006 - 05:52:26 PM »
Yes and no   :icon16: the old way was to grind to clean metal and spread the plastic filler onto bare steel but the with better primers and fillers the new way is to use an epoxy primer,rough it up and skim coat over that which keeps the metal protected and still adheres well.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline chall7074
« Reply #4 on: October 28, 2006 - 09:16:34 AM »
Thanks for the help I will go to the new member and introduce. I will be asking a lot more questions in the future. Will need alot more help.
Offline Steve
  • I Love Welding!
« Reply #5 on: October 29, 2006 - 07:31:46 AM »
Note that the PPG DP family of primers has a very narrow work window. They recommend you apply whatever you are going to apply within 7 days...this includes high-builds, fillers, etc. If you don't apply within 7 days, you must scuff and lay a fresh coat of DP epoxy. DP is a great product but it really makes the timing of your project difficult. Sign up for the forums at www.paintucation.com....there's a lot of information out there about using various products.
