Author Topic: Voltage limiter is different for rallye and non-rallye guages, correct?  (Read 1551 times)
Offline Grec
Auto parts place had three listings for non-rallye guages.  :banghead:
Sometimes those things are wrong, though.
Just double-checking.
Thanks.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline PlumCrazy
Re: Voltage limiter is different for rallye and non-rallye guages, correct?
« Reply #1 on: October 27, 2006 - 05:03:52 PM »
Same part.
Offline Grec
« Reply #2 on: October 27, 2006 - 07:42:20 PM »
Same part. Gotcha.
Thanks.
- 440 Six Pack
« Reply #3 on: October 27, 2006 - 08:07:57 PM »
Grec, before spending for an OE style look into buiding a solid state version. Local Mopar Guru said it can be done for under $10. in parts and will work & last better .
here's the how too.    http://www.allpar.com/history/mopar/electrical2.html
Offline CUDA JAS
  • vroooooom!
« Reply #4 on: October 28, 2006 - 11:35:34 AM »
SO for an E-body, you just add wires for each gauge fiorn the 5 volt side of the regulator??
Looks like and intersting upgrade!
Jas
 :working:
74 'cuda 360/727
Just call me a gearhead!
« Reply #5 on: October 28, 2006 - 12:06:57 PM »
Jas
 :working:
No that's not the way I see it, the soldering of wires to the cluster is not how I would do it.
I would re-create the limiter plugs with wires with male spade ends to plug in like the original piece
soo there would be 1 power in 1 power out & I believe the 3rd terminal is a ground.
This would be easier with small piece of breadboard.  :2cents:
Offline Grec
« Reply #6 on: October 28, 2006 - 10:39:25 PM »
I looked at that.
Heat wouldn't be an issue?
I was looking at gutting the stock limiter and wiring the chip inside so it would be plug and play. I got worried about the high temps of the dash...
- 440 Six Pack
« Reply #7 on: October 29, 2006 - 06:03:21 AM »
I'm not an electronics guru but my take is that has been done many times before so from the standpoint of heat on the solid state components I would not worry(think about all the hot places electronics are used), since they recommend a heat sink for the silicon chip it might be a good idea to locate it where it's heat could do no damage. Building it in the OE regulator body should take care of those concerns.
